Barnacle Potato Posted August 25, 2016 Share Posted August 25, 2016 Hello! I have a bike that isn't running, it tries to start but won't, I've had a look at everything and what is happening is fuel goes into the carb but doesn't go from the carb to the engine. In the pipe thing that connects the carb to the engine is completely dry but fuel is going into the carb. Do I need a new carb or is it fixable? ThanksFor what it sounds like; "> " onclick="window.open(this.href);return false; Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted August 25, 2016 Share Posted August 25, 2016 I kinda want to say that wants to go around 6 sec but I reckon that's wishful thinking.What does the plug look like after your starting attempts and does it spark if you rest it on the head and crank it over?If you've got spark you could try giving a couple of squirts of carb cleaner/easy-start down in the carb mouth. That'll at least tell you if the carb needs attention. Quote Link to comment Share on other sites More sharing options...
Barnacle Potato Posted August 25, 2016 Author Share Posted August 25, 2016 I kinda want to say that wants to go around 6 sec but I reckon that's wishful thinking.What does the plug look like after your starting attempts and does it spark if you rest it on the head and crank it over?If you've got spark you could try giving a couple of squirts of carb cleaner/easy-start down in the carb mouth. That'll at least tell you if the carb needs attention. The Sparks work, I've tried them and I'll see if I can get carb cleaner today. Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 25, 2016 Share Posted August 25, 2016 Where are you? Quote Link to comment Share on other sites More sharing options...
