Mcmurray0787 Posted June 4, 2020 Share Posted June 4, 2020 My chain's getting caught inside of my clutch casing and can't get it to quit can i just cut out the section its rubbing against will it hurt anything by chance?? Idk how to to post a pic but the section i wanna cut out is along side then magneto... Quote Link to comment Share on other sites More sharing options...
Tiggie Posted June 4, 2020 Share Posted June 4, 2020 Is your chain too slack? Does it need adjusting? Quote Link to comment Share on other sites More sharing options...
dynax Posted June 4, 2020 Share Posted June 4, 2020 What bike is it, is it new or used from a dealer or used from a private seller, do you have any warranty, as above have you checked that it is adjusted properly, has the size of front sprocket been changed or is stock, there is no need to go cutting bits out to solve the issue Quote Link to comment Share on other sites More sharing options...
WD-40 Posted June 4, 2020 Share Posted June 4, 2020 Was it ok and then all of a sudden it started rubbing or has it always been rubbing? Quote Link to comment Share on other sites More sharing options...
rennie Posted June 4, 2020 Share Posted June 4, 2020 Hello and Welcome Don't cut anything!You'll be able to post pics now you've posted.Something needs adjusting/replacing Quote Link to comment Share on other sites More sharing options...
JRH Posted June 6, 2020 Share Posted June 6, 2020 Hi and welcome.The chain shouldn’t touch anything. Don’t cut anything. First off check the tension and alignment. Quote Link to comment Share on other sites More sharing options...
fastbob Posted June 6, 2020 Share Posted June 6, 2020 Has someone put a bigger front sprocket on it by any chance ? Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted June 7, 2020 Share Posted June 7, 2020 Has someone put a bigger front sprocket on it by any chance ?Or replaced it with the wrong one, or put it on the wrong way round.. Quote Link to comment Share on other sites More sharing options...
