Troy Posted May 14, 2017 Share Posted May 14, 2017 June 10th, plan to make go to Thorpe Park on the motorcycle. It's the first time I have been on the bike so I was wondering if anyone else has been and could tell me if there storage lockers are large enough to keep my lid in there and kevlars, Well two actully as I'm taking a pillion. Quote Link to comment Share on other sites More sharing options...
Lowey Posted May 14, 2017 Share Posted May 14, 2017 Fairly sure that there are. After you have your tickets and walk through the booths...i believe they are under cover on your right hand side May want to check their website to be super sure though... Quote Link to comment Share on other sites More sharing options...
raesewell Posted May 14, 2017 Share Posted May 14, 2017 Why don't you just ring to ask them? Quote Link to comment Share on other sites More sharing options...
Stu Posted May 14, 2017 Share Posted May 14, 2017 Why don't you just ring to ask them? No need to do that We strongly recommend you use our lockers as loose items cannot be taken onto most rides, with the exception of some water rides. Lockers cost £1 and are non-refundable. https://www.thorpepark.com/faqs Lockers at Thorpe Park; SizesSmall lockers; 30cm x 40cm, (width x height).Medium lockers; 30cm x 60cm x 42cm, (width x height x depth) http://www.topdogdays.com/attraction/theme-park/thorpe-park/thorpe-park-lockers/ Quote Link to comment Share on other sites More sharing options...
raesewell Posted May 14, 2017 Share Posted May 14, 2017 There you go then. Another example of ask the forum because I can't be bothered to do some research Quote Link to comment Share on other sites More sharing options...
Troy Posted May 14, 2017 Author Share Posted May 14, 2017 Quote Link to comment Share on other sites More sharing options...
Lateralus Posted May 14, 2017 Share Posted May 14, 2017 There you go then. Another example of ask the forum because I can't be bothered to do some research It is secondary research though! Quote Link to comment Share on other sites More sharing options...
