Stu Posted March 25, 2020 Share Posted March 25, 2020 Frigging boiler gone tits up! Probably the worst time to do it! Quote Link to comment Share on other sites More sharing options...
XTreme Posted March 25, 2020 Share Posted March 25, 2020 Frigging boiler gone tits up! Probably the worst time to do it! Gas? Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted March 25, 2020 Share Posted March 25, 2020 Oops, what's happened? Just turned off? Quote Link to comment Share on other sites More sharing options...
Bender Posted March 25, 2020 Share Posted March 25, 2020 [mention]Stu[/mention] Make and issue? Quote Link to comment Share on other sites More sharing options...
Six30 Posted March 25, 2020 Share Posted March 25, 2020 bugger... whats up with her, is she breathing , have you rung the doctor or 111 ? Quote Link to comment Share on other sites More sharing options...
Bender Posted March 25, 2020 Share Posted March 25, 2020 bugger... whats up with her, is she breathing , have you rung the doctor or 111 ? I knew I just knew Quote Link to comment Share on other sites More sharing options...
Six30 Posted March 25, 2020 Share Posted March 25, 2020 Frigging boiler gone tits up! Probably the worst time to do it! Gas? she's been out with Dynax on the Heinz ? Quote Link to comment Share on other sites More sharing options...
Stu Posted March 25, 2020 Author Share Posted March 25, 2020 @Stu Make and issue? Ideal logic heat15+ not firing no error codes Tried resetting powering off bled radiators to check for air has been working today but no go now! Quote Link to comment Share on other sites More sharing options...
Stu Posted March 25, 2020 Author Share Posted March 25, 2020 Frigging boiler gone tits up! Probably the worst time to do it! Gas? I have plenty of that! Wife doesn't like it Quote Link to comment Share on other sites More sharing options...
Bender Posted March 25, 2020 Share Posted March 25, 2020 Heat only boiler, is it getting demand for heat, no error would indicate it thinks everything is fineCould be 3 way valve not switching or external control Quote Link to comment Share on other sites More sharing options...
Stu Posted March 25, 2020 Author Share Posted March 25, 2020 Heat only boiler, is it getting demand for heat, no error would indicate it thinks everything is fineCould be 3 way valve not switching or external control 3 port valve is moving when switching between heating and hot water etc pump circulates but the boiler just doesn't fire up Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted March 25, 2020 Share Posted March 25, 2020 Think you have a call out there @bender Quote Link to comment Share on other sites More sharing options...
Bender Posted March 25, 2020 Share Posted March 25, 2020 Is it displaying 0 on display? Quote Link to comment Share on other sites More sharing options...
Bender Posted March 25, 2020 Share Posted March 25, 2020 They are prone to fans, ignition units and sump clogging up if not cleaned but with that you usually hear a gurgling, but if it's displays not changing from, 0 the boiler pcb is either f**ked or it's not getting signal for heat, ie back to external control Quote Link to comment Share on other sites More sharing options...
rennie Posted March 25, 2020 Share Posted March 25, 2020 Oh dear! Good luck getting someone out to that! Quote Link to comment Share on other sites More sharing options...
Bender Posted March 25, 2020 Share Posted March 25, 2020 Oh dear! Good luck getting someone out to that! Heating off is fine, it's if you get shafted for the repair price is issue at mo, most plumbers gas fitters still doing repairs. Quote Link to comment Share on other sites More sharing options...
Stu Posted March 25, 2020 Author Share Posted March 25, 2020 Is it displaying 0 on display? Yes showing 0 no burner light Quote Link to comment Share on other sites More sharing options...
Stu Posted March 25, 2020 Author Share Posted March 25, 2020 They are prone to fans, ignition units and sump clogging up if not cleaned but with that you usually hear a gurgling, but if it's displays not changing from, 0 the boiler pcb is either f**ked or it's not getting signal for heat, ie back to external control Thats all not sounding good! I have had the sump changed as it cracked about a year ago and serviced at the same time I have a guy coming tomorrow Quote Link to comment Share on other sites More sharing options...
Bender Posted March 25, 2020 Share Posted March 25, 2020 Usually there is a single switch wire to fire up boiler it's first one to the left of mains inlet on boiler panel, it's marked sl1 if that has no voltage it's doing nothing.Still think it's external, I would pop round but it's a tad out the road. Quote Link to comment Share on other sites More sharing options...
Stu Posted March 25, 2020 Author Share Posted March 25, 2020 Usually there is a single switch wire to fire up boiler it's first one to the left of mains inlet on boiler panel, it's marked sl1 if that has no voltage it's doing nothing.Still think it's external, I would pop round but it's a tad out the road. I have figured out that I have hot water side but not central heating I shorted the room stat to rule that and still nothing Quote Link to comment Share on other sites More sharing options...
Bender Posted March 25, 2020 Share Posted March 25, 2020 Sounds like return wire from port valve Quote Link to comment Share on other sites More sharing options...
Stu Posted March 25, 2020 Author Share Posted March 25, 2020 Sounds like return wire from port valve Sounds like an easy fix then Quote Link to comment Share on other sites More sharing options...
Bender Posted March 25, 2020 Share Posted March 25, 2020 Usually just the valve head Quote Link to comment Share on other sites More sharing options...
Stu Posted March 25, 2020 Author Share Posted March 25, 2020 Hopefully that's all it is! Cheers bender I would sort it myself but I will let this guy do it! Quote Link to comment Share on other sites More sharing options...
Stu Posted March 26, 2020 Author Share Posted March 26, 2020 [mention]Bender[/mention] divert valve as you said Quote Link to comment Share on other sites More sharing options...
