James in Brum Posted March 27, 2020 Share Posted March 27, 2020 You lot know stuff I don’t.I have tried google and eBay and failed. I want something to fit to my submersible water pump to reduce the current outlet which is 50mm with femal thread to 25mm so I can attach my hose. I cannot find something to do that. Do any of you know where I can? Quote Link to comment Share on other sites More sharing options...
Stu Posted March 27, 2020 Share Posted March 27, 2020 pics? Quote Link to comment Share on other sites More sharing options...
James in Brum Posted March 27, 2020 Author Share Posted March 27, 2020 Goof idea. Will come back with one when I can, probably tomorrow. Quote Link to comment Share on other sites More sharing options...
XTreme Posted March 27, 2020 Share Posted March 27, 2020 ....... Quote Link to comment Share on other sites More sharing options...
rennie Posted March 27, 2020 Share Posted March 27, 2020 I could have helped if I was at workbut for now you've dipped out I'm afraid Quote Link to comment Share on other sites More sharing options...
fifthwheel Posted March 27, 2020 Share Posted March 27, 2020 There is a good chance your fittings will be BSP and not metric. Very common available everywhere. Google BSP fittings. Hope this helps as they say. Quote Link to comment Share on other sites More sharing options...
Ian Frog Posted March 27, 2020 Share Posted March 27, 2020 Would one of those adjustable restrictors that Hozelock do for their pond pumps be any good?CheersIan Quote Link to comment Share on other sites More sharing options...
James in Brum Posted March 28, 2020 Author Share Posted March 28, 2020 46 outside diameter in my and 38 internal diameter mm. [attachment=1]4F5056DC-906C-467D-BC14-3FFC7099CEE8.jpeg[/attachment] That is to screw into the pump ‘out’. I need something to reduce to 25mm ish for this hose. [attachment=0]F86C0659-AEE9-4318-B8C7-13E1EF3F7628.jpeg[/attachment] Quote Link to comment Share on other sites More sharing options...
James in Brum Posted March 28, 2020 Author Share Posted March 28, 2020 I am not the best with technology Quote Link to comment Share on other sites More sharing options...
Mack01 Posted March 28, 2020 Share Posted March 28, 2020 If you can't find it online then get onto a 3D printer forum. Those folks can print so many different things that one of them is bound to be able to for you. Quote Link to comment Share on other sites More sharing options...
James in Brum Posted March 28, 2020 Author Share Posted March 28, 2020 Thanks Quote Link to comment Share on other sites More sharing options...
EX GASMAN Posted March 29, 2020 Share Posted March 29, 2020 is this ant good?https://www.ebay.co.uk/itm/50mm-Rubber-Connector-Adapter-Reducer-50-to-25mm-Water-Supply-Pipe-Pushfit-/322491232929or this?https://www.drainagecentral.co.uk/Flexseal-PVC-Plumbing-Adaptor-Coupling-48mm-43mm-38mm-32mm-048-038?gclid=Cj0KCQjwjoH0BRD6ARIsAEWO9Ds3phMYCmKaxTPMXTC50aRN_mRBC5jXC-Pyq4rZlVPYh0532btyu68aApHOEALw_wcB Quote Link to comment Share on other sites More sharing options...
Ian Frog Posted March 29, 2020 Share Posted March 29, 2020 is this ant good?https://www.ebay.co.uk/itm/50mm-Rubber-Connector-Adapter-Reducer-50-to-25mm-Water-Supply-Pipe-Pushfit-/322491232929or this?https://www.drainagecentral.co.uk/Flexseal-PVC-Plumbing-Adaptor-Coupling-48mm-43mm-38mm-32mm-048-038?gclid=Cj0KCQjwjoH0BRD6ARIsAEWO9Ds3phMYCmKaxTPMXTC50aRN_mRBC5jXC-Pyq4rZlVPYh0532btyu68aApHOEALw_wcBGreat find !At those prices it would be worth ordering and seeing what they can do.I am fairly sure with a couple of jubilee clips or possibly plumbers plastic cement you will have cracked it for him.CheersIan Quote Link to comment Share on other sites More sharing options...
James in Brum Posted March 29, 2020 Author Share Posted March 29, 2020 Thank you will look Quote Link to comment Share on other sites More sharing options...
