onesea Posted June 19, 2020 Share Posted June 19, 2020 Do the following damage coatings on glasses?1. Anti-fog spray which you spray on your glasses after cleaning 2. Cleaning your glasses with washing up liquid and then leaving them to dry 3. Cleaning your glasses with shaving foam and then leaving them to dry 4. Anti-fog wipesNow meant to wear masks at work all the freaking time. Not been needed since the beginning but now....Luckily I don't need glasses to drive but I do to read the SatNav... Quote Link to comment Share on other sites More sharing options...
husoi Posted June 19, 2020 Share Posted June 19, 2020 Or you can go to an optician because if your glasses are that damaged likely is that you are due a new appointment Quote Link to comment Share on other sites More sharing options...
raesewell Posted June 19, 2020 Share Posted June 19, 2020 All of the above should have no detrimental effect on your specs.The shaving foam and washing liquid leave a bit of fog on the glass. Muc Off or Bob Heaths anti fog are good. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted June 19, 2020 Share Posted June 19, 2020 Some coatings may be affected by strong detergents. I've damaged glasses by cleaning with washing up liquid but that's a while ago and over a long period of time.To be fair I used neat washing up liquid rather than diluting it. But I found it did degrade the coating and made them prone to scratches. I use the wet glasses wipes now and they clean without damaging the surface. Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted June 19, 2020 Share Posted June 19, 2020 When I first bought glasses with an anti-reflective coating I was warned to keep away from alcohol wipes (annoying because they work brilliantly..) but anything gentler should be fine. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted June 19, 2020 Share Posted June 19, 2020 When I first bought glasses with an anti-reflective coating I was warned to keep away from alcohol wipes (annoying because they work brilliantly..) but anything gentler should be fine. Interesting as that's what I always use on mine, which have anti reflective coating. Doesn't seem to cause a problem. I went over to them as everything else I used ended up damaging the lenses. I do them every morning as I hate marks on the lenses. Quote Link to comment Share on other sites More sharing options...
James in Brum Posted June 21, 2020 Share Posted June 21, 2020 Do the following damage coatings on glasses?1. Anti-fog spray which you spray on your glasses after cleaning 2. Cleaning your glasses with washing up liquid and then leaving them to dry 3. Cleaning your glasses with shaving foam and then leaving them to dry 4. Anti-fog wipesNow meant to wear masks at work all the freaking time. Not been needed since the beginning but now....Luckily I don't need glasses to drive but I do to read the SatNav...To avoid fogging glasses make sure the top of the mask contours well to your nose and cheeks. Fogging is a sign that the mask is not on properly and therefore also not doing its job, at least with clinical face masks. Air pushing up out the top and fogging your glasses is not being caught by the mask. I’m sure this is not news to you, it was to me when I complained. Quote Link to comment Share on other sites More sharing options...
onesea Posted June 21, 2020 Author Share Posted June 21, 2020 To avoid fogging glasses make sure the top of the mask contours well to your nose and cheeks. Fogging is a sign that the mask is not on properly and therefore also not doing its job, at least with clinical face masks. Air pushing up out the top and fogging your glasses is not being caught by the mask. I’m sure this is not news to you, it was to me when I complained. I am aware but when you are wearing them for a 10 hour+ shift changing them regularly, keeping a good seal is a challenge. A smile or conversation is enough to steam glasses up, not ideal when divining over ear ones are a nightmare tie ones easier.Plus the requirement to wear them when driving 2 up is new. Having worked throughout to be suddenly be told NOW you shall, wheres as at the beginning we where told No you shall not... Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted June 21, 2020 Share Posted June 21, 2020 Follow the science. Ha bloody ha! Which science exactly are we supposed to be following? At least there now seems to be some consensus on wearing masks in certain circumstances. That said I know surgeons change their masks regularly during a longer operation. How many ordinary people are doing the same? Also WTF is it with folks you see driving their cars solo and wearing a mask? Quote Link to comment Share on other sites More sharing options...
dynax Posted June 21, 2020 Share Posted June 21, 2020 I have seen people sat in their own gardens wearing masks Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted June 21, 2020 Share Posted June 21, 2020 I suppose if it makes them feel better or happier I shouldn't mock. Each to his own but I'll only be wearing them when I absolutely have to. Not worn one yet but that won't last. Quote Link to comment Share on other sites More sharing options...
James in Brum Posted June 21, 2020 Share Posted June 21, 2020 To avoid fogging glasses make sure the top of the mask contours well to your nose and cheeks. Fogging is a sign that the mask is not on properly and therefore also not doing its job, at least with clinical face masks. Air pushing up out the top and fogging your glasses is not being caught by the mask. I’m sure this is not news to you, it was to me when I complained. I am aware but when you are wearing them for a 10 hour+ shift changing them regularly, keeping a good seal is a challenge. A smile or conversation is enough to steam glasses up, not ideal when divining over ear ones are a nightmare tie ones easier.Plus the requirement to wear them when driving 2 up is new. Having worked throughout to be suddenly be told NOW you shall, wheres as at the beginning we where told No you shall not...I’m in the same boat. I know what you mean, it’s really tough. My advice was only in case you haven’t heard it. Quote Link to comment Share on other sites More sharing options...
James in Brum Posted June 21, 2020 Share Posted June 21, 2020 Except I do get breaks from nine in the day. Do not as badly as you have it. Quote Link to comment Share on other sites More sharing options...
