Albrynmair Posted September 26, 2017 Share Posted September 26, 2017 Hi,For some reason I struggle to turn right out of a give way/junction I pull up and get rather anxious about shooting across the road into the ditch when I pull up to a junction in 1st and can see enough both ways I am ok and can pull out, but when I stop that’s when it happens.Even today I stoped and tried to pull out but had to put my right foot down to stop the bike going over. Other times I can turn right no problems! Any advice would be gratefully appreciated.Kind Regards,Al Quote Link to comment Share on other sites More sharing options...
bonio Posted September 26, 2017 Share Posted September 26, 2017 Hey Al. Try this and see if it helps: after checking the road is clear, just before you move off, turn your head to the right, and look straight down the middle of the road you're turning into. Keep looking down the road while making the turn. Quote Link to comment Share on other sites More sharing options...
raesewell Posted September 26, 2017 Share Posted September 26, 2017 Just get more practice, it'll come good. Quote Link to comment Share on other sites More sharing options...
goat Posted September 26, 2017 Share Posted September 26, 2017 When turning right don't pull up perpendicular to the turn, pull up angled towards the direction you are turning so you have less of a turn to make. The advice about looking down the road is very good as well. Quote Link to comment Share on other sites More sharing options...
Westbeef Posted September 26, 2017 Share Posted September 26, 2017 Hi mate also try dragging the rear brake and slipping the clutch it makes the bike much more stable Quote Link to comment Share on other sites More sharing options...
2WheelSolo Posted September 27, 2017 Share Posted September 27, 2017 I think we all end up with wierd issues in our head. The trick is to just go out and practice again and again until it becomes second nature.Angling the bike is a good suggesting. The other - which I use with my son who has exactly the same issue as you - is to turn the bars to the right before you start off. It will force you to lean the bike and make a tighter turn and you'll be so busy doing that you'll forget to worry about the ditch etc on the other side Quote Link to comment Share on other sites More sharing options...
Hoggs Posted September 27, 2017 Share Posted September 27, 2017 Also try not to overthink it too much but I am aware that is much easier to say than do. Once you get a few good ones under your belt it will become second nature as you won't subconsciously tense up which makes turning trickier. We've all had issues like this - I still find I brake a hell of a lot more for right turns than lefts. Even though I am aware the bike will easily go round faster than I am taking it.The other key thing is don't try and do too much too soon because you'll get frustrated - aim for one good turn in the next week and take it from there! Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted September 27, 2017 Share Posted September 27, 2017 When you are turning right are you taking up a position at the extreme right hand side of your lane?When I did my test (many moons ago) the examiner commented that riders are taught to adopt a position to the right of the lane but this has two disadvantages, 1) it means anyone cutting the corner takes you out, 2) it makes turning right harder. He advised me to forget what I'd been taught to do and to take up a position a couple of feet to the left - ie nearer the middle of the lane.Over the years that has saved me getting swiped by cars cutting the corner, but it does also give you that bit more room - maybe it's psychological, but having a bit of space means it feels different. I still find that if I come to a tight right hand turn and I have had to take the extreme right hand position I can feel myself being more conscious of controlling the bike in the turn.Don't be afraid to slip the clutch - bike clutches aren't like car clutches - they run in oil so slipping them doesn't cause the same wear as slipping a car clutch. Quote Link to comment Share on other sites More sharing options...
mike_1984 Posted September 28, 2017 Share Posted September 28, 2017 your probs overthinking it as hoggs says, i still catch myself doing the same in wet weather as im still a bit nervous it seems (crap tyres and few offs in rain apparntly have scarred my brain )and start to over analyse my riding once that starts, turns i can take at 40mph+ without a thought suddenly become 15mph battles of wills between me and the bike lol Relax, practice and go with it try not to over think it Quote Link to comment Share on other sites More sharing options...
Joeman Posted September 28, 2017 Share Posted September 28, 2017 Just close your eyes and go for it.. can't have target fixation if you cant see the target.. Quote Link to comment Share on other sites More sharing options...
goat Posted September 28, 2017 Share Posted September 28, 2017 http://a.dilcdn.com/bl/wp-content/uploads/sites/6/2017/05/37-anh-luke-xwing-use-the-force.jpg Quote Link to comment Share on other sites More sharing options...
AlunJ Posted October 2, 2017 Share Posted October 2, 2017 I used to do the exact same thing. When I'm stopped, I turn the bars slightly to the right and once ready to pull away look straight down the road where you are heading. It's all too easy to look at what you're trying to avoid and that's exactly where the bike will go. Practice makes perfect and you'll get there Quote Link to comment Share on other sites More sharing options...
Joeman Posted October 2, 2017 Share Posted October 2, 2017 At a right hand junction, it's it's flat I stop with my right foot down so the bike is already learning over to the right. That makes it much easier to pull away. Quote Link to comment Share on other sites More sharing options...
Bender Posted October 2, 2017 Share Posted October 2, 2017 Don't look at the far curb/cars, practice tight turns right and left going slow, even if you have to go to a quiet road/industrial estate. Quote Link to comment Share on other sites More sharing options...
Liveware Problem Posted October 5, 2017 Share Posted October 5, 2017 When you are turning right are you taking up a position at the extreme right hand side of your lane?When I did my test (many moons ago) the examiner commented that riders are taught to adopt a position to the right of the lane but this has two disadvantages, 1) it means anyone cutting the corner takes you out, 2) it makes turning right harder. He advised me to forget what I'd been taught to do and to take up a position a couple of feet to the left - ie nearer the middle of the lane.Over the years that has saved me getting swiped by cars cutting the corner, but it does also give you that bit more room - maybe it's psychological, but having a bit of space means it feels different. I still find that if I come to a tight right hand turn and I have had to take the extreme right hand position I can feel myself being more conscious of controlling the bike in the turn.Don't be afraid to slip the clutch - bike clutches aren't like car clutches - they run in oil so slipping them doesn't cause the same wear as slipping a car clutch. I do that too, fed up of the number of cars that drastically cut corners. Quote Link to comment Share on other sites More sharing options...
Yeldur Posted October 10, 2017 Share Posted October 10, 2017 I'm still a newbie to motorbikes and I'm sitting on L plates, but, the one thing my instructor told me that I've always applied is "Look where you want to go and that's where you'll go" - Might be helpful to you. I believe Roadcraft Nottingham has a video on turning your bars to face the direction you want to turn as well, that's helped me a lot as well. Quote Link to comment Share on other sites More sharing options...
