potatobroxd Posted February 17, 2019 Share Posted February 17, 2019 I was wondering if you'd get a severely uneven pair of tires if you if leaned right more than you do left? (roundabouts for example) as my commute seems to only consist of leaning right for both ways. Quote Link to comment Share on other sites More sharing options...
Liveware Problem Posted February 17, 2019 Share Posted February 17, 2019 Possibly..? My scooter had a ridiculousy uneven wear pattern by the time I finally changed it, after 17,800 miles, the left side was completely smooth but the right still had plenty of tread. Quote Link to comment Share on other sites More sharing options...
potatobroxd Posted February 17, 2019 Author Share Posted February 17, 2019 Possibly..? My scooter had a ridiculousy uneven wear pattern by the time I finally changed it, after 17,800 miles, the left side was completely smooth but the right still had plenty of tread. would there be any noticeable handling issues if that were the case? Quote Link to comment Share on other sites More sharing options...
Liveware Problem Posted February 17, 2019 Share Posted February 17, 2019 From my experience, yes. I didn't realise how bad it was until I'd got a new tyre, with the worn tyre the bike would twitch and pull under braking, and it wouldn't tip into corners in a predictable way. Quote Link to comment Share on other sites More sharing options...
TimR Posted February 17, 2019 Share Posted February 17, 2019 uk road network is heavily based on turning right under power ie roundabouts .and road camber http://www.cambriantyres.co.uk/motorcycle-tyre-wears-more-on-right-side/ Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted February 17, 2019 Share Posted February 17, 2019 The road camber can be enough to wear the right side of the tyre more than the left, in the UK. Add roundabouts to the mix and you will wear the right side more than the left. Quote Link to comment Share on other sites More sharing options...
gogs01 Posted February 17, 2019 Share Posted February 17, 2019 If a roundabout is at a crossroads, then :1. If I take exit 1 I'll be on the left of the tyre more than the right2. Exit 2 ? left, right, left - and powering out, so more wear on left than right3. Exit 3 ? left, right, right, left - more time on right, but again powering out on left. Let's say even.4. Going round and round before deciding on an exit - definitely more wear on rightSo, are we going out of our way to wear out the right side of the tyre on roundabouts ?? I can see road camber, misaligned wheels and bent frames, or even taking a circular commute every day having an effect, but I'd be surprised if uneven wear was due to roundabouts. Quote Link to comment Share on other sites More sharing options...
potatobroxd Posted February 17, 2019 Author Share Posted February 17, 2019 If a roundabout is at a crossroads, then :1. If I take exit 1 I'll be on the left of the tyre more than the right2. Exit 2 ? left, right, left - and powering out, so more wear on left than right3. Exit 3 ? left, right, right, left - more time on right, but again powering out on left. Let's say even.4. Going round and round before deciding on an exit - definitely more wear on rightSo, are we going out of our way to wear out the right side of the tyre on roundabouts ?? I can see road camber, misaligned wheels and bent frames, or even taking a circular commute every day having an effect, but I'd be surprised if uneven wear was due to roundabouts. I tend to go round the roundabout a couple times before exiting to practice cornering; maybe I should reverse the wheels every thousand miles? Are there dangers of doing so? Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted February 17, 2019 Share Posted February 17, 2019 Most tyres are directional so reversing them isn't advised. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2019 Share Posted February 17, 2019 Psst.......don't tell him about the arrow on the sidewall........."snigger"....... Quote Link to comment Share on other sites More sharing options...
potatobroxd Posted February 17, 2019 Author Share Posted February 17, 2019 Psst.......don't tell him about the arrow on the sidewall........."snigger"....... I am aware that there's an arrow on the sidewall, I'm wondering about the possible dangers from doing so on a bike as Im sure you can do it on a car?*im guessing it could be due water not being able to disperse properly? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 17, 2019 Share Posted February 17, 2019 No - it's because the plies are laid onto the carcass with an overlap.....if you run the tyre the "wrong" way, then the plies could unwind, and that might be "interesting". Obviously, if there's no arrow......... Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted February 17, 2019 Share Posted February 17, 2019 You would probably invalidate your insurance if you put them on the wrong way round Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted February 17, 2019 Share Posted February 17, 2019 Also the rotation of the planets would be reversed, time would run backwards and the universe would implode. This would invalidate your insurance and generally be a bad thing.**Except for dinosaurs - but then we'd have no petrol so every motorcyclist in the world would be seriously inconvenienced. Quote Link to comment Share on other sites More sharing options...
Bungleaio Posted February 17, 2019 Share Posted February 17, 2019 More trips to the continent will sort you out. Quote Link to comment Share on other sites More sharing options...
gogs01 Posted February 17, 2019 Share Posted February 17, 2019 .....I am aware that there's an arrow on the sidewall, I'm wondering about the possible dangers from doing so on a bike as Im sure you can do it on a car? ..... The tyres on my car are directional too ..... Quote Link to comment Share on other sites More sharing options...
