Tuckermoto Posted June 8, 2019 Share Posted June 8, 2019 Hi allThe bike has been running ok after engine rebuild but when I went to start the bike today the engine management light was very dim and when turned over it acted like a flat battery ..I checked voltage and across the terminals it was showing 12.5 v...so I put battery on charge over night ..I’ve tested today and battery showing a good 12.78 volts but I have no power at all no ignition no power when ignition is switched on ..no engine management light every thing is dead could this be the main fuse and if so where is it or is this a Honda gremlin Quote Link to comment Share on other sites More sharing options...
Tuckermoto Posted June 8, 2019 Author Share Posted June 8, 2019 Just jumped bike via a booster pack and all working ok but when booster pack disconnected it stops I have rechecked the battery and it’s only showing 12v so looks like a dud battery so I have ordered one I have checked and alternator is charging Quote Link to comment Share on other sites More sharing options...
