Breadsnapper Posted August 25, 2019 Share Posted August 25, 2019 Quick question, had the misses on the back of my CBR600 and the back end is quite low. I know I will have to adjust the rear shock so do I wind the collar out to lengthen the spring or wind it in to make it shorter. I am of the opinion I wind it out but suspension is witchcraft to me.Cheers in advanceDave. Quote Link to comment Share on other sites More sharing options...
dynax Posted August 25, 2019 Share Posted August 25, 2019 Wind it out the aim is to have the bike level when loaded, you may need to increase tyre pressure too by a couple of psi Quote Link to comment Share on other sites More sharing options...
Breadsnapper Posted August 25, 2019 Author Share Posted August 25, 2019 Yeah I thought so but cheers for that. Alternatively she could lose some weight. Just don't tell her I said that Quote Link to comment Share on other sites More sharing options...
dynax Posted August 25, 2019 Share Posted August 25, 2019 just had a quick google and suggests taking as far one way then count back number of turns the other then go halfway back and start from there might need a bit of trial and error Quote Link to comment Share on other sites More sharing options...
Breadsnapper Posted August 25, 2019 Author Share Posted August 25, 2019 Cheers I will give it a go. Just what I need messing about on my bike in the baking heat when I could be out in my own riding it.Dave. Quote Link to comment Share on other sites More sharing options...
oldgrump Posted August 25, 2019 Share Posted August 25, 2019 Normally you would just adjust the damping up, there's normally a screw and that adjust the damping, And not the spring!!! I would find the damping screw and put a turn on that towards heavy , making a note of how much you turn it, so you can turn back for solo use. Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 25, 2019 Share Posted August 25, 2019 Wind it out the aim is to have the bike level when loaded, you may need to increase tyre pressure too by a couple of psi No you don't , you wind it in to increase spring preload . I honestly would have thought that was obvious . Quote Link to comment Share on other sites More sharing options...
Breadsnapper Posted August 25, 2019 Author Share Posted August 25, 2019 Wind it out the aim is to have the bike level when loaded, you may need to increase tyre pressure too by a couple of psi No you don't , you wind it in to increase spring preload . I honestly would have thought that was obvious . So I wind the spring in ? Quote Link to comment Share on other sites More sharing options...
manxie49 Posted August 25, 2019 Share Posted August 25, 2019 Ditto with Dynax, don't forget the tyre pressures, really important Quote Link to comment Share on other sites More sharing options...
Six30 Posted August 25, 2019 Share Posted August 25, 2019 Leave her indoors ......Custard creams . Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted August 25, 2019 Share Posted August 25, 2019 Buy a Bobber.No pillion seat.Sorted. Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 25, 2019 Share Posted August 25, 2019 Wind it out the aim is to have the bike level when loaded, you may need to increase tyre pressure too by a couple of psi No you don't , you wind it in to increase spring preload . I honestly would have thought that was obvious . So I wind the spring in ? Compress the spring . Quote Link to comment Share on other sites More sharing options...
One Ball 1971 Posted August 25, 2019 Share Posted August 25, 2019 Yeah dont touch the settings, just go out alone with the excuse the engine isn't big enough for 2 people lol Quote Link to comment Share on other sites More sharing options...
skyrider Posted August 25, 2019 Share Posted August 25, 2019 Yeah I thought so but cheers for that. Alternatively she could lose some weight. Just don't tell her I said that yes that might earn you some cold lunches for a while Quote Link to comment Share on other sites More sharing options...
dynax Posted August 25, 2019 Share Posted August 25, 2019 Wind it out the aim is to have the bike level when loaded, you may need to increase tyre pressure too by a couple of psi No you don't , you wind it in to increase spring preload . I honestly would have thought that was obvious . Stand corrected Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 25, 2019 Share Posted August 25, 2019 Wind it out the aim is to have the bike level when loaded, you may need to increase tyre pressure too by a couple of psi No you don't , you wind it in to increase spring preload . I honestly would have thought that was obvious . Stand corrected A pleasure to be of assistance . Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 25, 2019 Share Posted August 25, 2019 I don't know why they even put pillion seats and pegs on mid range sports bikes . It's just not what they are designed to do . Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted August 25, 2019 Share Posted August 25, 2019 I don't know why they even put pillion seats and pegs on mid range sports bikes . It's just not what they are designed to do . Same reason they put indicators on BMWs and Audis. Quote Link to comment Share on other sites More sharing options...
