What did you do to your bike today? (part 4)
Motorbike related? Can't find what you're looking for below? Then post here!!
Richzx6r
Gender: Male
Bike(s): Kawasaki zx6r j1 and a1p 636
Challenge score: 30
Has liked: 3654 times
Been liked: 1252 times
Re: What did you do to your bike today? (part 4)
Post by Richzx6r » Thu Feb 06, 2020 9:28 pm
dynax wrote:
Thu Feb 06, 2020 8:36 pm
@Richzx6r have you got a multimeter or a volt meter to take a reading of the voltage, some chargers won't charge if the voltage is too low to be recognised, it might be possible to put some charge in with jump leads from a car battery, might be worth a go if you can :thumb:
I do have a multimeter but it doesn't work, also I'll try jump leads first before I take the battery back
Its better when its loaded
User avatar
dynax
Subscriber
Gender: Male
Bike(s): Xena, Bridget, Florence (WIP)
Has liked: 2300 times
Been liked: 1324 times
Post by dynax » Sat Feb 08, 2020 4:25 pm
Xena is all ready now barring a good clean, Bridget on the other hand needs a bit more managed to get her running but it was a struggle and looks like she may need a new battery after all, luckily she has a kickstart, next thing will be adjusting the brakes and changing the oil in the forks as they seem to bottom out rather quickly with very little pressure, and it sounds as if there is a small leak in the exhaust which will need to done, other than that and a good clean she is all good :thumb:
Mike, just cruising around with Xena 8-)
https://www.youtube.com/channel/UCmihUc ... subscriber
User avatar
Mickly
Subscriber
Gender: Male
Bike(s): 15my Speed Triple / 1994 1200 triumph Trophy
Challenge score: 410
Has liked: 392 times
Been liked: 710 times
Post by Mickly » Sat Feb 08, 2020 6:22 pm
Was down the garage listening to the ‘chasin the racing ‘ pod cast, so engrossed listening I spent 2 hours looking for the cable that connects the starter solenoid to the starter motor, only to discover that it was already fitted to the starter motor & the other end was hidden under the carbs 😡
Mind you it’s a good listen.
2020 challenge points
3/10 Hoggs Bonus
5/12 South West
1/12 South East
9/12 Midlands
2/15 Bike Dealers
1/12 East Midlands
10/10 Churches
4/10 Pubs
gogs01
Bike(s): R1200RT
Has liked: 159 times
Been liked: 146 times
Post by gogs01 » Sat Feb 08, 2020 8:25 pm
Replaced the bike's battery and fitted twin horns ..... :)
I was hoping to have all the plastics back on, but that's now a job for tomorrow ...... :shock:
User avatar
Bender
Moderator
Gender: Male
Has liked: 2162 times
Been liked: 2503 times
Post by Bender » Sat Feb 08, 2020 9:08 pm
Hmmm now that's something I had been planning to do, what did you fit?
I have had to lift the tank on mine as the battery needed a bit of a charge.
Bite my shiny metal ass..
gogs01
Bike(s): R1200RT
Post by gogs01 » Sun Feb 09, 2020 12:01 pm
Replaced the bike's battery .....
I went for a Motobatt MBYZ16HD. An AGM battery that can live on it's side or upside down and doesn't need an initial charge - just fit and go. It was a couple of millimetres less tall than the original Exide but fitted fine.
Ordered from Tayna Batteries, it cost less than half what I would have paid at the BMW dealer, has a higher ampere rating (16.5AH against 14) and CCAmps are 240 against the original 170. All good so far .....
User avatar
Snod Blatter
Gender: Male
Bike(s): CBX250RS-E CB250N Two Fifty TRX850 K100RS Z250SL
Has liked: 1480 times
Been liked: 353 times
Post by Snod Blatter » Sun Feb 09, 2020 12:38 pm
Yesterday I tightened the Kawasaki's chain as it had become loose enough to just touch the oiler and then took the CBX out in a show of rugged individualism that would make Xtreme proud :roll:
Today I'm just worrying about the things getting blown over.
Richzx6r
Gender: Male
Challenge score: 30
Post by Richzx6r » Sun Feb 09, 2020 1:05 pm
I hope you gave the water a go??
James in Brum
Subscriber
Bike(s): ZZR600D1
Has liked: 130 times
Been liked: 464 times
Post by James in Brum » Sun Feb 09, 2020 2:57 pm
I rode her back from Coventry where I left her on Friday night. That was a challenging and interesting ride!
Time spent being groovy to each other is always well
Spent
User avatar
Snod Blatter
Gender: Male
Post by Snod Blatter » Sun Feb 09, 2020 3:10 pm
Are you mad!? You can clearly see the pedestrian bridge on the right..
User avatar
dynax
Subscriber
Gender: Male
Post by dynax » Sun Feb 09, 2020 3:13 pm
You just need the right bike :lol:
Richzx6r
Gender: Male
Challenge score: 30
Post by Richzx6r » Sun Feb 09, 2020 3:43 pm
To answer your question yes I am mad
User avatar
dynax
Subscriber
Gender: Male
Post by dynax » Sun Feb 09, 2020 3:49 pm
It is possible to aquaplane across a body of water if the bike is fairly light and the speed is just right and the angle of entry is not too steep, i watched an episode of Mythbusters and they rode across a small lake on a bike :thumb:
Bianco2564
Subscriber
Gender: Male
Bike(s): R1,Silverwing,RGV250,GT380,SS125!Velosolex
Has liked: 128 times
Been liked: 446 times
Post by Bianco2564 » Sun Feb 09, 2020 5:14 pm
Took the wheels off of the scooter in anticipation of fitting new boots.
Bit disappointed in the life I've got out of the Contiscoot tyres, only around 3000 miles or so, fitted them in October iirc.
The rear tyre is completely shot, pressures all been ok.
I do ride it fairly hard and its quite a heavy bike but 3000 miles is worse than I get out of a rear tyre on my 150hp R1 :shock:
The underside of it was completely plastered in mud, so took all that off and gave it a wash.
All this was done outside this morning dodging the torrential rain showers.
User avatar
Mississippi Bullfrog
Subscriber
Gender: Male
Bike(s): Honda CBF500 ABS Triumph Bobber
Has liked: 857 times
Been liked: 2350 times
Post by Mississippi Bullfrog » Thu Feb 13, 2020 12:53 pm
Went out on the CBF and got soaked. It came on heavy halfway there and the package in the back meant I'd had to leave the waterproofs at home.
When I got home I fitted the new fly screen to the Bobber.
Honda CBF500 ABS
Triumph Bobber
Return to “Motorbike Chat”
Who is online
Users browsing this forum: CommonCrawl [Bot], fullscreenaging and 5 guests
