What did you do to your bike today? (part 4)
Motorbike related? Can't find what you're looking for below? Then post here!!
James in Brum
Subscriber
Bike(s): ZZR600D1
Has liked: 130 times
Been liked: 464 times
Re: What did you do to your bike today? (part 4)
Post by James in Brum » Sun Feb 16, 2020 6:37 am
Thanks @fastbob what’s in clover in fixing it?
@JRH i look forwards to getting her a geared fifty in a little over a decade, if she want one :/)
Time spent being groovy to each other is always well
Spent
James in Brum
Subscriber
Bike(s): ZZR600D1
Post by James in Brum » Sun Feb 16, 2020 7:44 am
This is what the Haynes shows...
Spent
TimR
Gender: Male
Has liked: 35 times
Been liked: 565 times
Post by TimR » Sun Feb 16, 2020 8:36 am
Zzr from memory is not vacuum fed
Zzr1100 d is on and off
Zzr1100 c is on and off
Zzr600 e had on off res
If you tilt the tank too far it will come out of the overflow. Best to remove tank fully if working on bike as they are prone to being weak near the rear mount and corrode .
Do something ( marker pen or red lenstape) to difuse / cover over those fuel lights as at night they will blind you if flashing and distract you .....
The woods are lovely, dark and deep,
But I have promises to keep,
And miles to go before I sleep,
And miles to go before I sleep.
Robert Frost
fastbob
Gender: Male
Bike(s): Harley Davidson 1200 Roadster and another ER5
Has liked: 3107 times
Been liked: 3858 times
Post by fastbob » Sun Feb 16, 2020 9:18 am
What's involved in fixing it ? ( 😁 ) Usually the microscopic hole in this component has become blocked and needs poking through . I use a single bristle from a fine wire brush or a piece of guitar string ( High E ) Oddly , in the drawing , the diaphragms are not illustrated and they are the fiddly bit .
James in Brum
Subscriber
Bike(s): ZZR600D1
Post by James in Brum » Sun Feb 16, 2020 9:22 am
Thanks for responses. Would process mean entirely empty tank to be able to take that off and apart?
Spent
fastbob
Gender: Male
Post by fastbob » Sun Feb 16, 2020 9:40 am
Not completely empty , as long as you can lean it against the wall with the level below the tap and filler . If you want to avoid spillage you could stick a brake hose clamp on the fuel line . Or use a small pair of pliers and a zip tie .
Bianco2564
Subscriber
Gender: Male
Bike(s): R1,Silverwing,RGV250,GT380,SS125!Velosolex
Has liked: 128 times
Been liked: 446 times
Post by Bianco2564 » Sun Feb 16, 2020 11:52 am
Can't you siphon some fuel out to make it easier?
Bianco2564
Subscriber
Gender: Male
Post by Bianco2564 » Sun Feb 16, 2020 11:54 am
Finished putting the wheels back in the Silverwing and took it for a gentle ride; New tyres, damp roads, steady as she goes.
User avatar
dynax
Subscriber
Gender: Male
Bike(s): Xena, Bridget, Florence (WIP)
Has liked: 2300 times
Been liked: 1324 times
Post by dynax » Mon Feb 17, 2020 2:25 pm
Done Bridgets starter, this is what it looked like when i first took it apart to do a temp fix :thumb:
All done now with the new Brush set
Now back on Bridget and working great, also new sparkplug fitted and brakes tweeked a bit more while i had the spanners out :thumb:
Mike, just cruising around with Xena 8-)
https://www.youtube.com/channel/UCmihUc ... subscriber
User avatar
Stu
Site Admin
Gender: Male
Bike(s): FJR1300 & BMW F650ST
Has liked: 4059 times
Been liked: 3541 times
Post by Stu » Mon Feb 17, 2020 2:40 pm
You should be doing a write up in a separate thread of what you have done and why :thumb:
Fines are taxes for doing bad, taxes are fines for doing good.
James in Brum
Subscriber
Bike(s): ZZR600D1
Post by James in Brum » Mon Feb 17, 2020 6:21 pm
I would appreciate it if you did @dynax
Help me learn of this stuff works :-)
Spent
User avatar
dynax
Subscriber
Gender: Male
Post by dynax » Tue Feb 18, 2020 2:51 pm
Bridget is all back together now, just finished the last few jobs, cleaning and refitting the front sprocket cover and the chain guard, and i only have a couple of bits left over :thumb: , one is a locking washer but for a splined bolt or something and a little plastic bung no idea where that goes so overall pretty happy, she just needs a good clean and polish now :cheers:
User avatar
dynax
Subscriber
Gender: Male
Post by dynax » Tue Feb 18, 2020 2:52 pm
i will get something up when i get the chance and i will have to try and source some pictures from the web as i only took a couple of photos myself :thumb:
Ian Frog
Subscriber
Gender: Male
Bike(s): ZRX1200R, Supercharged Busa, Busa, HarleyDyna
Has liked: 438 times
Been liked: 899 times
Post by Ian Frog » Tue Feb 18, 2020 3:11 pm
Hi Mate
It is worth checking the front sprocket nut as these are often secured with a washer that bends over and the shaft is splined.
Just thinking that if the nut did spin loose it could be a disaster.
Hopefully I am wrong !
Cheers
Ian
User avatar
dynax
Subscriber
Gender: Male
Post by dynax » Tue Feb 18, 2020 3:15 pm
Hi Mate
Cheers
Ian
Not the front sprocket already checked the main possibilities :scratch: not to worry if it's something crucial i'm sure i will soon find out :lol:
Return to “Motorbike Chat”
Who is online
Users browsing this forum: CommonCrawl [Bot], fastbob, sm0129, Tweetmeme [Bot] and 7 guests
