AdzTorn Posted May 17, 2020 Share Posted May 17, 2020 Does the power commander 5 work on my bike as on the website it doesn’t have the option for mine , or I’m I being dumb and not seeing it ? Quote Link to comment Share on other sites More sharing options...
fastbob Posted May 17, 2020 Share Posted May 17, 2020 A Power Commander on a 125 single ? Honestly ? Quote Link to comment Share on other sites More sharing options...
dynax Posted May 17, 2020 Share Posted May 17, 2020 Just googled it to see what it was, that is funny Quote Link to comment Share on other sites More sharing options...
raesewell Posted May 17, 2020 Share Posted May 17, 2020 He's probably got some money burning a hole in his pocket Quote Link to comment Share on other sites More sharing options...
Stu Posted May 17, 2020 Share Posted May 17, 2020 obviously some people underestimate what a power commander is all about Its not all about getting more power! the OP might have a snatchy throttle and want to smooth it out Quote Link to comment Share on other sites More sharing options...
raesewell Posted May 17, 2020 Share Posted May 17, 2020 Snatchy throttle = feather the clutch Quote Link to comment Share on other sites More sharing options...
fastbob Posted May 17, 2020 Share Posted May 17, 2020 The bike already has variable cam shafts and EFI . Quote Link to comment Share on other sites More sharing options...
Stu Posted May 17, 2020 Share Posted May 17, 2020 Snatchy throttle = feather the clutch no good when coming out of a corner and winding the throttle on! this was the reason the power commander was created as the TL1000s which is was originally created for was like an on and off switch and a lot of bikes are still the same The bike already has variable cam shafts and EFI . And your point is? Quote Link to comment Share on other sites More sharing options...
fastbob Posted May 17, 2020 Share Posted May 17, 2020 Snatchy throttle = feather the clutch no good when coming out of a corner and winding the throttle on! this was the reason the power commander was created as the TL1000s which is was originally created for was like an on and off switch and a lot of bikes are still the same The bike already has variable cam shafts and EFI . And your point is? That it is already designed to extract the optimum performance from 125 cc's . Quote Link to comment Share on other sites More sharing options...
Stu Posted May 17, 2020 Share Posted May 17, 2020 Snatchy throttle = feather the clutch no good when coming out of a corner and winding the throttle on! this was the reason the power commander was created as the TL1000s which is was originally created for was like an on and off switch and a lot of bikes are still the same The bike already has variable cam shafts and EFI . And your point is? That it is already designed to extract the optimum performance from 125 cc's . I will guarantee its not! it will run very lean at low revs like all bikes to meet emissions standards and this is the reason you have a snatchy throttle on EFI bikes A power commander can easily richen this up and smooth throttle control at lower speeds Its not all about best performance and power! sometimes its about ride ability! Quote Link to comment Share on other sites More sharing options...
fastbob Posted May 17, 2020 Share Posted May 17, 2020 Ok then , here you go . https://www.magnumtuning.com/en/detail/dyno-boost-motorcycle-performance-chip/yamaha/mt-125 Quote Link to comment Share on other sites More sharing options...
AdzTorn Posted May 17, 2020 Author Share Posted May 17, 2020 Only reason am asking is because I’ve added a full exhaust system and I read on the internet that the bikes probably running more lean now. Am just a newbie wanting some helpful tips from those with more knowledge Quote Link to comment Share on other sites More sharing options...
Stu Posted May 17, 2020 Share Posted May 17, 2020 Only reason am asking is because I’ve added a full exhaust system and I read on the internet that the bikes probably running more lean now. Am just a newbie wanting some helpful tips from those with more knowledge How does it feel when you ride it? Quote Link to comment Share on other sites More sharing options...
fastbob Posted May 17, 2020 Share Posted May 17, 2020 I just tried to watch a couple of MT125 tuning videos but I couldn't stomach the racist gangster violence soundtracks . ( Honestly ) Quote Link to comment Share on other sites More sharing options...
