Troy Posted June 17, 2020 Share Posted June 17, 2020 I’m looking to get a slip-on for my CBR. I was looking at a Scorpion or an Akrapovic. I know the Akra is better but the price difference is huge. I’ve had a Scorpion before with no issues and I personally feel it is a good brand and it’s a lot cheaper. Someone has recently said though that the Scorpion in his opinion, can cause sputtering... True or False?Let me know your thoughts and suggestions. Quote Link to comment Share on other sites More sharing options...
Gerontious Posted June 17, 2020 Share Posted June 17, 2020 I swapped the OE for a Scorpion on my bike, Ive noticed no difference apart from the way the bike looks. with the baffle out its really quite loud though. too loud for my taste.If its a 'normal' exhaust then it will have been designed to closely match the characteristics of the original. you only get a real change when you swap the entire system. or go 'Race'.I went for the ceramic black. Quote Link to comment Share on other sites More sharing options...
Stu Posted June 17, 2020 Share Posted June 17, 2020 You won't know how the bike will react until you fit it All bikes are different most run fine and some need to be set back up again Carbed bikes are worse when fitting aftermarket exhausts you lose a bit of back pressure which affects the fuelling more than a EFI bike Quote Link to comment Share on other sites More sharing options...
