onesea Posted June 19, 2016 Share Posted June 19, 2016 OK my partner now goes Pillion quite happily my Lidl best intercom with plug between the 2 helmet works....Unless your doing over 40 mph you are both listening to the same music and you cannot talk over it.... Plus you have to unplug and plug in every time you get on the bike.None of this is difficult but is there a set out there that....1) Reduces coms problems due to wind etc2) Uses FM Bluetooth or what ever so we can talk when when not connected by wire,3) Allows music to be played (bluetooth/ phone satnav) and us to talk over it (or has vox operation),4) Allows greater control over phone than music start/ stop and last number dialed,5) Allows intercommunication between other intercom systems (friends etc)6) Has FM Radio for listening,These are probably in order of priority for us any suggestions? If it cannot achieve 3/4 out of the 6 above we maybe better of with the £20 Lidel option. Quote Link to comment Share on other sites More sharing options...
Stu Posted June 19, 2016 Share Posted June 19, 2016 I have a scala rider Q3 which does pretty much most of that! Although number 4 is pretty limited with all systems and number 5 is usually if you have the same system too Quote Link to comment Share on other sites More sharing options...
Arwen Posted June 19, 2016 Share Posted June 19, 2016 We have a pair of the Q3's too. Works a treat. I especially like the adaptive volume. It lowered the volume when there is less "outside" noise. I was surprised with how good the FM signal was too. Quote Link to comment Share on other sites More sharing options...
Joeman Posted June 19, 2016 Share Posted June 19, 2016 Sena 20shttp://www.sena.com/product/20s/" onclick="window.open(this.href);return false;I bought one because Phil told me to.. ticks most of the boxes you mention. Quote Link to comment Share on other sites More sharing options...
Joeman Posted June 19, 2016 Share Posted June 19, 2016 I have a scala rider Q3 which does pretty much most of that! Although number 4 is pretty limited with all systems and number 5 is usually if you have the same system too For number 4 - Use the Phone's voice commands to do stuff.. "Ok Google, navigate to.... " etcfor 5 - the Sena 20s has "Universal Intercom" that's supposed to work with other brands of intercom. no idea how good that is though. Quote Link to comment Share on other sites More sharing options...
Stu Posted June 19, 2016 Share Posted June 19, 2016 For number 4 - Use the Phone's voice commands to do stuff.. "Ok Google, navigate to.... " etc No thanks I have a Garmin zumo 590 that does everything I need! Sat nav, phone controls and music Quote Link to comment Share on other sites More sharing options...
rob m Posted June 19, 2016 Share Posted June 19, 2016 Scala Rider G9x. Does all of those things. Quote Link to comment Share on other sites More sharing options...
Oasis Posted June 19, 2016 Share Posted June 19, 2016 I have a scala rider Q3 which does pretty much most of that! Although number 4 is pretty limited with all systems and number 5 is usually if you have the same system too For number 4 - Use the Phone's voice commands to do stuff.. "Ok Google, navigate to.... " etcfor 5 - the Sena 20s has "Universal Intercom" that's supposed to work with other brands of intercom. no idea how good that is though."Ok google" in its latest form only monitors the internal mic. Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Joeman Posted June 19, 2016 Share Posted June 19, 2016 I have a scala rider Q3 which does pretty much most of that! Although number 4 is pretty limited with all systems and number 5 is usually if you have the same system too For number 4 - Use the Phone's voice commands to do stuff.. "Ok Google, navigate to.... " etcfor 5 - the Sena 20s has "Universal Intercom" that's supposed to work with other brands of intercom. no idea how good that is though."Ok google" in its latest form only monitors the internal mic. Nope, it works perfectly from Bluetooth with my phone, and from wired headphones. Quote Link to comment Share on other sites More sharing options...
Oasis Posted June 19, 2016 Share Posted June 19, 2016 On which handset?Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Joeman Posted June 19, 2016 Share Posted June 19, 2016 On which handset? Nexus 5xjust need to go into Google Now settings and enable bluetooth headset.Also set it to always listen even when the phone is locked.But i set the headset as a trusted BT device so the phone stays unlocked whilst paired. Quote Link to comment Share on other sites More sharing options...
Oasis Posted June 19, 2016 Share Posted June 19, 2016 On which handset? Nexus 5xjust need to go into Google Now settings and enable bluetooth headset.Also set it to always listen even when the phone is locked.But i set the headset as a trusted BT device so the phone stays unlocked whilst paired.Ah right, well all though the option is in the settings for Samsung and HTC it only monitors the internal mic to instigate the ok google app. Once it has been started you can then use the Bluetooth mic to talk to the app. Pointless on a bike if you have a nav app going as you would have to stop the bike, go to the home screen, press the mic icon and then speak.Looks like google got it right with their own nexus handsets. Even running Google now doesn't help.Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Stu Posted June 20, 2016 Share Posted June 20, 2016 Ok Google works for me too with a headset I just don't use it Quote Link to comment Share on other sites More sharing options...
onesea Posted June 20, 2016 Author Share Posted June 20, 2016 I though "OK Google" did not work on my Lidl headset but maybe it will now going to have to try it with new settings..Great side track...I also found this:http://moto-intercom.co.uk/news/blog/6-intercom-systems-for-motorcycles-with-conference" onclick="window.open(this.href);return false;Quite a neat comparison... Quote Link to comment Share on other sites More sharing options...
onesea Posted August 2, 2016 Author Share Posted August 2, 2016 Just thought I would update this as I have still not resolved...I have been looking at com's systems between me and Misses my Lidl set is still working but if you want to talk you cannot hear the SatNav.This is good reference if 2 years old:http://moto-intercom.co.uk/news/blog/6-intercom-systems-for-motorcycles-with-conference" onclick="window.open(this.href);return false;Cardo:http://www.cardosystems.com/wp-content/uploads/2015/02/comparison-chart-2015-International.png" onclick="window.open(this.href);return false;Sena:Sadly I cannot find such a handy little tableSeems the top end Sena and Cardo systems give music & satnav overlayed with intercom... Whilst looking the following set came to my attention (probably on here), looks a good set but misses a few features for Pillion but thought others might be interested £85...http://www.mobilefun.co.uk/cardo-scala-rider-qz-motorcycle-bluetooth-hands-free-kit-p45476.htm#description" onclick="window.open(this.href);return false;Or top end this one is cheap if you have spare cash....http://www.tritoncycles.co.uk/accessories-c11/communication-systems-c207/cardo-scala-rider-packtalk-system-p14683" onclick="window.open(this.href);return false;http://www.tritoncycles.co.uk/accessories-c11/communication-systems-c207/cardo-scala-rider-packtalk-duo-system-p14685/s42809?utm_source=google&utm_medium=cpc&utm_term=cardo-scala-rider-packtalk-duo-system-btsrptd&utm_campaign=product%2Blisting%2Bads&gclid=CjwKEAjw5vu8BRC8rIGNrqbPuSESJADG8RV0XYc_rt2vR_CoEUW-6nrDv0pqiEsdQ7belwNLxvXw9RoCzFHw_wcB" onclick="window.open(this.href);return false;Just ideas Quote Link to comment Share on other sites More sharing options...
toad Posted February 10, 2017 Share Posted February 10, 2017 @ oneseaHave you managed to sort it yet? I'm ambivalent... On the one hand you can go and spend wads of cash (£300 +), on the other these things go dirt cheap (£30). Add to that that you don't always get what you pay for and you don't always pay for what you get.If anyone knows of a system with a decent range, say half a mile, which is easy to use and manages a whole day, say ten hours, on batteries then I'm in! SatNav instructions are par for the course I reckon. Oh, and should be under £100. I'm still looking. Quote Link to comment Share on other sites More sharing options...
onesea Posted February 10, 2017 Author Share Posted February 10, 2017 We went for Packtalk Duo worth it?Yes Communication up to the speed limit of fine, we can do a long day 8-10 hours Talking intercom by the end of the day we are getting low battery alarms (never had flat battery).Once set up talking to others on other bikes is useful. The chat over coffee can continue long after coffee. Changes in routes/ destinations can be discussed.If roding in a bigger pack as leader the other bike can be your eyes as to if every one is with you. And No. The system is not without its limitations, and can be a frustrating. If you have any problems Cardo Support is good for set up issues.If you regularly change riding groups it can be frustrating. The controls can be difficult for certain features. Presently away for couple of days on bike in the snow :/ Once back home if you went I will give better review. To save money I would not consider Smartpack it would be very easy to get to 4 riders. We have that problem coming to us one couple bought SmartPack. Once we get 5 of us out together.... Quote Link to comment Share on other sites More sharing options...
toad Posted February 11, 2017 Share Posted February 11, 2017 Hm, it's got a decent range which is important and apparently is capable of up to 15 participants which would result in talkture Anyway, enjoy the snow Quote Link to comment Share on other sites More sharing options...
Guest Posted February 12, 2017 Share Posted February 12, 2017 I bought the packtalk duo recently after having so many issues with more than 5 sena 20s units.So far I don't have any real faults worth mentioning but I'm quite confident these are the best on the market after research and my experience of them.They are expensive but if you're in the market for a decent intercom and ride with a partner or a group, these are fantastic. Quote Link to comment Share on other sites More sharing options...
onesea Posted February 19, 2017 Author Share Posted February 19, 2017 Right I am back and updating as promised...Interestingly I had to do factory reset on the way home it was doing odd things....Glitchy but good is my answer if you want to talk to others and have music PACKTALK If you want to talk to your Pillion ONLY and not have music go cheap, unless you want coms over 60 mph...I have no experience with Sena but as its said not to be water proof....My review...https://themotorbikeforum.co.uk/viewtopic.php?f=83&t=61488&p=980721#p980721Any questions ask...https://themotorbikeforum.co.uk/viewtopic.php?f=83&t=61488&p=980721#p980721 Quote Link to comment Share on other sites More sharing options...
