Phooey Posted February 8, 2017 Share Posted February 8, 2017 So after nearly four years I thought that I would treat myself to a new pair of motorcycle boots. The left boot fits like a glove but the right hurts my lickle toe!After an hour or so of riding my little toe become sore enough to become evident by a slight limp. My old boots never did this so the question is, do I man up and wait till they break in or is there something I can do to speed up the process? Quote Link to comment Share on other sites More sharing options...
Mawsley Posted February 8, 2017 Share Posted February 8, 2017 Cut a hole for your little toe to peek out from? Quote Link to comment Share on other sites More sharing options...
Phooey Posted February 8, 2017 Author Share Posted February 8, 2017 Cut a hole for your little toe to peek out from? lol ... I expected something sarcastic not funny! Quote Link to comment Share on other sites More sharing options...
JRH Posted February 8, 2017 Share Posted February 8, 2017 Chop the offending toe off. You used to be able to get shoe stretchers, dont know if you still can of even get then into the foot area of the boot. Quote Link to comment Share on other sites More sharing options...
Arwen Posted February 8, 2017 Share Posted February 8, 2017 Are they leather boots? If so, you could try boot stretchers, or the old "stuff it full of newspaper and leave somewhere warmish for a while. If they are not mostly leather, then you probably need a size up... Unless thicker socks are not an option? Quote Link to comment Share on other sites More sharing options...
Mawsley Posted February 8, 2017 Share Posted February 8, 2017 While we still have them - get Johnny Foreigner to walk about in your boots for £1.62 per week. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted February 8, 2017 Share Posted February 8, 2017 I had something similar recently. I got the leather warm and then worked at the offending area with my thumb. I was surprised how quickly and easily the leather gave a bit and they're fine now. Quote Link to comment Share on other sites More sharing options...
old-timer Posted February 8, 2017 Share Posted February 8, 2017 Does your toe hurt from friction (between boot/sock and toe) or pressure (not enough space i.e. boot a bit too small)?.If it is friction, you might try a tube of some sort of 'stretch fabric', lined inside with gel.It may also help in case of pressure, but of course it leaves even less space inside the boot.You just cut off a piece and slide it over the toe, thus forming a kind of buffer between toe and whatever is irritating it. Hoping that after a while your boot has adjusted to your foot enough not to be a 'pain' anymore.A mild form of arthroses has deformed one of my toes a bit, so it won't stretch out.In some shoes (and indeed my motorcycle boot) I use such a tube to prevent the toe from rubbing the upper inside of the shoe.They are for sale in drugstores or maybe even in supermarkets.So if tricks for making the boot a bit more specious don't work, this may help (temporarily). Quote Link to comment Share on other sites More sharing options...
TimR Posted February 8, 2017 Share Posted February 8, 2017 Have you removed all the packaging ..... Quote Link to comment Share on other sites More sharing options...
Tango Posted February 8, 2017 Share Posted February 8, 2017 Which make of boots are they?......my old Sidis were always tight.....even after 5 years......and I even went up a size because I'd heard that they're normally pretty snug........my TCX's on the other hand are super comfy......and they're my normal size...... Quote Link to comment Share on other sites More sharing options...
Bhawk Posted February 9, 2017 Share Posted February 9, 2017 Does your toe hurt from friction (between boot/sock and toe) or pressure (not enough space i.e. boot a bit too small)?.If it is friction, you might try a tube of some sort of 'stretch fabric', lined inside with gel.It may also help in case of pressure, but of course it leaves even less space inside the boot.You just cut off a piece and slide it over the toe, thus forming a kind of buffer between toe and whatever is irritating it. Hoping that after a while your boot has adjusted to your foot enough not to be a 'pain' anymore.A mild form of arthroses has deformed one of my toes a bit, so it won't stretch out.In some shoes (and indeed my motorcycle boot) I use such a tube to prevent the toe from rubbing the upper inside of the shoe.They are for sale in drugstores or maybe even in supermarkets.So if tricks for making the boot a bit more specious don't work, this may help (temporarily).Geltube.jpg oooooh thats what thats for, ive been using it completely wrong, never had a friction sore on my todger though! Quote Link to comment Share on other sites More sharing options...
old-timer Posted February 9, 2017 Share Posted February 9, 2017 oooooh thats what thats for, ive been using it completely wrong, never had a friction sore on my todger though! But... but... these are made especially for toes and fingers.So how in the world did you manage to... ??? Oh well... if it fits, why not ? Quote Link to comment Share on other sites More sharing options...
Phooey Posted February 9, 2017 Author Share Posted February 9, 2017 Are they leather boots? If so, you could try boot stretchers, or the old "stuff it full of newspaper and leave somewhere warmish for a while. If they are not mostly leather, then you probably need a size up... Unless thicker socks are not an option? They are leather ... I might thicker socks to cushion a bit. Quote Link to comment Share on other sites More sharing options...
Phooey Posted February 9, 2017 Author Share Posted February 9, 2017 Does your toe hurt from friction (between boot/sock and toe) or pressure (not enough space i.e. boot a bit too small)?.If it is friction, you might try a tube of some sort of 'stretch fabric', lined inside with gel.It may also help in case of pressure, but of course it leaves even less space inside the boot.You just cut off a piece and slide it over the toe, thus forming a kind of buffer between toe and whatever is irritating it. Hoping that after a while your boot has adjusted to your foot enough not to be a 'pain' anymore.A mild form of arthroses has deformed one of my toes a bit, so it won't stretch out.In some shoes (and indeed my motorcycle boot) I use such a tube to prevent the toe from rubbing the upper inside of the shoe.They are for sale in drugstores or maybe even in supermarkets.So if tricks for making the boot a bit more specious don't work, this may help (temporarily).Geltube.jpg Definitely wortha try ... thanks Quote Link to comment Share on other sites More sharing options...
