Mawsley Posted October 13, 2017 Share Posted October 13, 2017 Shit or not? Quote Link to comment Share on other sites More sharing options...
Gerontious Posted October 13, 2017 Share Posted October 13, 2017 Looks exactly the same as this one. which apparently is made in the UK... i nearly fell off my chair when I read that.https://www.sgs-engineering.com/sc24h-24-litre-high-flow-air-compressor Quote Link to comment Share on other sites More sharing options...
Stu Posted October 13, 2017 Share Posted October 13, 2017 They are just rebranded generic compressors depending on what you are planning on doing with it will dictate whether its good enough or not They are good in what they are designed to do and compress air but as I say depends on the job in hand Quote Link to comment Share on other sites More sharing options...
Arwen Posted October 13, 2017 Share Posted October 13, 2017 I've bought from sgs before. Very helpful company should I would have no brother ordering from them. Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted October 13, 2017 Share Posted October 13, 2017 I've got one of those although it's branded "Wolf" (Raaaa!).It's noisy, the fittings are made from the finest Chinesium but it does compress air which is good enough for inflating tyres (including popping beads) and running a windy gun. It can't quite keep up with a die grinder but what do you expect for 80 pictures?The only good thing in the £15 quid kit is the blow gun. The rest is shatpank. Screwfix do much better bits for just a bit more money. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted October 14, 2017 Share Posted October 14, 2017 As Mr Fro - I have the same thing but in yellow branded Wolf. It does what I need it to - the tank is quite small on that one, mine is the 50l version which I've used to run rattle guns and a cellulose spray gun. I paint cars a panel at a time and it just about does that. No good for doing a total respray on a car.For pumping up tyres etc that will be fine. No good for running any air tools that use a lot of air though - eg drills, grinders.It will come with Euro fittings rather than UK - the cheap air tools from Lidl / Aldi come with Euro fittings.I bought a good quality spray gun and just screwed the Euro connection onto it. You can buy all the connections online.Don't buy cheap hose, you need decent hose. Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted October 14, 2017 Share Posted October 14, 2017 It will come with Euro fittings rather than UK - the cheap air tools from Lidl / Aldi come with Euro fittings.I bought a good quality spray gun and just screwed the Euro connection onto it. You can buy all the connections online.Don't buy cheap hose, you need decent hose. Good point. I junked the hose from mine and use a 10mm robber job. I also take directly from the tank and use PLC XL fittings which help flow and give you a bit more oomph at the tool. Quote Link to comment Share on other sites More sharing options...
Mawsley Posted October 14, 2017 Author Share Posted October 14, 2017 I've got one of those although it's branded "Wolf" (Raaaa!).It's noisy, the fittings are made from the finest Chinesium but it does compress air which is good enough for inflating tyres (including popping beads) and running a windy gun. It can't quite keep up with a die grinder but what do you expect for 80 pictures?The only good thing in the £15 quid kit is the blow gun. The rest is shatpank. Screwfix do much better bits for just a bit more money. Idea binned. Cheers Quote Link to comment Share on other sites More sharing options...
taylordouglas203 Posted October 17, 2017 Share Posted October 17, 2017 What are you using it for?Sent from my SM-J510FN using Tapatalk Quote Link to comment Share on other sites More sharing options...
