TitanBax Posted March 31, 2018 Share Posted March 31, 2018 Hi everyone, my first proper post, and as expected it is asking for advice - sorry.I have a massive head, and helmet shopping is always a bit depressing. I have a limited choice of manafacturers, and normally have a choice of ether black or white helmets. No fancy MotoGP replicas for me.I have only ever had Shoeis When I first started riding, I went to 5 shops just to find a helmet that fit, and that was the Shoei XR800, I then had a XR1000, I took time away from bikes, then came back and now have a Qwest. I liked it at first, but now find it is annoying me. 1) I find it really noisy. I cant recall the XR1000 being that bad. I wear ear plugs.2) the pin lock moves around such that when I breathe, air gets in the bottom and doesn't disappear. I find the visor difficult to shut and when you open it, the pin lock gets moved about a bit. I guess I am asking if anyone else has had trouble with the shoei, and have a way to solve any of the issues (mainly the pin lock one) I don't have the money to buy a new helmet currently.CheersTitanBax Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted March 31, 2018 Share Posted March 31, 2018 Hi TB.I've had a few niggles with the visor on my Shoei too. When I got it the visor wouldn't quite close right so I got a whistle at speed. If you lift the visor you can slacken the hinge screws and move them a bit to make it fit better.It takes a bit of trial and error to get it right but is doable if you've got the patience. Same thing with the pinlock - just keep adjusting it until you can see the seal is touching the visor all the way round.For the wind noise coming underneath, did the Qwest have a neck guard thing? It looks like a tiny bib - they can help. Quote Link to comment Share on other sites More sharing options...
JRH Posted March 31, 2018 Share Posted March 31, 2018 The pinlock pins are eccentric and by turning them you can put more pressure against the visor and so create a strong seal. You can test this with a piece of paper. If you can push it past the edge seal it needs more pressure. It can take a bit of patience to get it right. Pinlock do an additional 3 part pin which gives more adjustment if necessary. Quote Link to comment Share on other sites More sharing options...
