HomerPlata Posted April 18, 2018 Share Posted April 18, 2018 Nah, not another one of those wanky internet challenges, just a way of opening the topic "who the hell gets anywhere near maximum temperature on these things?"I can only use 40% max before it gets too uncomfortable. How high do you guys go? Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 18, 2018 Share Posted April 18, 2018 Never seen the point of heating the palms of my hands when my arse is freezing off . Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted April 18, 2018 Share Posted April 18, 2018 Never seen the point of heating the palms of my hands when my arse is freezing off . I've also fitted heated seats on the Busa Bob Quote Link to comment Share on other sites More sharing options...
Gerontious Posted April 18, 2018 Share Posted April 18, 2018 Nah, not another one of those wanky internet challenges, just a way of opening the topic "who the hell gets anywhere near maximum temperature on these things?"I can only use 40% max before it gets too uncomfortable. How high do you guys go? You have to bear in mind that these are a kinda 'one size fits all'.. some bars are notoriously hard to heat.. the heat being conducted away from the grips by whatever alloy has been used.. i think this is the case for some bars that are made from aluminium alloy. So, for these the heater has to work that much harder to maintain a temperature in the grips. Whereas other bars made from steel. will absorb the heat and not lose it so quickly due to conduction. Quote Link to comment Share on other sites More sharing options...
HomerPlata Posted April 18, 2018 Author Share Posted April 18, 2018 You have to bear in mind that these are a kinda 'one size fits all'.. some bars are notoriously hard to heat.. the heat being conducted away from the grips by whatever alloy has been used.. i think this is the case for some bars that are made from aluminium alloy. So, for these the heater has to work that much harder to maintain a temperature in the grips. Whereas other bars made from steel. will absorb the heat and not lose it so quickly due to conduction. Fair point, never thought of that. I just thought it might have been a bravado thing, like choosing the hottest curry off the menu to impress a bird Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 18, 2018 Share Posted April 18, 2018 Never seen the point of heating the palms of my hands when my arse is freezing off . I've also fitted heated seats on the Busa Bob Ah well , now you're talking! Quote Link to comment Share on other sites More sharing options...
Six30 Posted April 18, 2018 Share Posted April 18, 2018 My bike came with heated grips, first time I've ever had em on a bike .... they will never get used though , if it's that cold out I won't be going out . Quote Link to comment Share on other sites More sharing options...
TimR Posted April 18, 2018 Share Posted April 18, 2018 It revolves around your gloves.If their summer styled you will feel the heat more than a true winter glove Quote Link to comment Share on other sites More sharing options...
someone Posted April 18, 2018 Share Posted April 18, 2018 Never seen the point of heating the palms of my hands when my arse is freezing off . Because unless there is something badly wrong with you, you arse is fatter than your fingers!I always used to assume that grips would only heat the inside of the hand, and do nothing for the outside of the fingers which receive the impact of the wind. Instead I had heated glove liners for cold weather which were okay.Then I got a bike with heated grips installed and discovered I was very badly wrong.The heat spreads though the hand just fine. Whilst the insides of them are warmer, the outsides still feel better than they did in the liners. And I feel more in control without having the extra layer of padding between my fingers and the bike.They are official Honda grips though so only have three settings, but that is plenty for all situations. Quote Link to comment Share on other sites More sharing options...
Lanceautoman Posted April 18, 2018 Share Posted April 18, 2018 I fitted some oxford grips to my YBR a couple of weeks ago when it was still cold. I never go above 50%! Quote Link to comment Share on other sites More sharing options...
Stu Posted April 18, 2018 Share Posted April 18, 2018 I have a better challengeThe post in the correct section challenge Don't worry I have moved your thread to the correct one As [mention]Gerontious[/mention] says the bars alone have a lot to do with the heat outputI can easily have mine on max any less and it's hardly worth having on! Quote Link to comment Share on other sites More sharing options...
MR_W Posted April 18, 2018 Share Posted April 18, 2018 In winter I can easily run at 100%, most normally it's either 50 or 75. Quote Link to comment Share on other sites More sharing options...
Guest Posted April 20, 2018 Share Posted April 20, 2018 And next....how many lines of Wasabi can you snort? Quote Link to comment Share on other sites More sharing options...
Westbeef Posted April 20, 2018 Share Posted April 20, 2018 I did my lessons through the winter, I had the grips on 100% . My gloves were cheap Aldi ones and started to melt at points. Quote Link to comment Share on other sites More sharing options...
MR_W Posted April 20, 2018 Share Posted April 20, 2018 And next....how many lines of Wasabi can you snort? None. But I do get very cold hands hence why I run a higher setting than most. Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted April 20, 2018 Share Posted April 20, 2018 I had the hot grips on my last bike and could easily use 100% but I wore summer gloves all year round Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted April 21, 2018 Share Posted April 21, 2018 I have these grips on my Tiger 800 and rarely use them above 50% but I do have winter gloves. Quote Link to comment Share on other sites More sharing options...
okupant Posted April 29, 2018 Share Posted April 29, 2018 During winter months, on my daily early morning half an hour commute to work, I had heated grips on 75% most of the time. And I wore winter gloves. Quote Link to comment Share on other sites More sharing options...
