narp Posted January 30, 2019 Share Posted January 30, 2019 If you don't mind.I notice some trousers - both textile and leather, are actually dungarees - but why?What advantage disadvantage is there to a dungaree? Quote Link to comment Share on other sites More sharing options...
Gerontious Posted January 30, 2019 Share Posted January 30, 2019 Salopettes.And the advantage, especially in winter is that regardless of riding position your jacket will always overlap enough that there won't be any cold air getting where it shouldn't.. They're warmer. Quote Link to comment Share on other sites More sharing options...
narp Posted January 30, 2019 Author Share Posted January 30, 2019 Ahhhh - I see - anti-draught pants.Thanks. Quote Link to comment Share on other sites More sharing options...
Arwen Posted January 30, 2019 Share Posted January 30, 2019 High trousers = no builders cleavage. Quote Link to comment Share on other sites More sharing options...
Tankbag Posted January 30, 2019 Share Posted January 30, 2019 No good for a quick wazz tho Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted January 30, 2019 Share Posted January 30, 2019 No good for a quick wazz tho Ah but if you keep warm you’re less likely to need to wazz so often. But if you want to be able to wazz with frequency and wear colder gear then it becomes a self fulfilling situation. So do I be prepared to go and therefore need to go? Or do I risk inconvenience but then maybe not need to go in the first place? This is the dilemma of winter riding. Quote Link to comment Share on other sites More sharing options...
Tankbag Posted January 30, 2019 Share Posted January 30, 2019 No good for a quick wazz tho Ah but if you keep warm you’re less likely to need to wazz so often. But if you want to be able to wazz with frequency and wear colder gear then it becomes a self fulfilling situation. So do I be prepared to go and therefore need to go? Or do I risk inconvenience but then maybe not need to go in the first place? This is the dilemma of winter riding. Always, always, go when you can Quote Link to comment Share on other sites More sharing options...
Andy ham Posted January 30, 2019 Share Posted January 30, 2019 I found through experience that the disadvantage with the dungeree style is you end up making an arse of yourself jumping around like a cat on a hot tin roof when ya need a slash Quote Link to comment Share on other sites More sharing options...
JRH Posted January 30, 2019 Share Posted January 30, 2019 No good for a quick wazz tho Ah but if you keep warm you’re less likely to need to wazz so often. But if you want to be able to wazz with frequency and wear colder gear then it becomes a self fulfilling situation. So do I be prepared to go and therefore need to go? Or do I risk [strikeout]inconvenience[/strikeout] incontinence but then maybe not need to go in the first place? This is the dilemma of winter riding. Fixed it for you Quote Link to comment Share on other sites More sharing options...
narp Posted January 31, 2019 Author Share Posted January 31, 2019 I understand the convention in a wet-suit is to simply let it go and enjoy the warmth - perhaps a combination of a high-pant and water-proof boots would afford the motorcyclist the same comfort on those cold days?It's a very good reason to not buy your wet-suit second-hand. Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted January 31, 2019 Share Posted January 31, 2019 Ok if properly disinfected Quote Link to comment Share on other sites More sharing options...
Throttled Posted January 31, 2019 Share Posted January 31, 2019 The overlap for the cold also helps keep you dry and if you are in an accident, keeps your skin covered. When I had my accident I ended up with road rash on the side of my waist. So now I wear braces with the trousers (that do not zip onto the jacket) to keep them up. Quote Link to comment Share on other sites More sharing options...
