jem1 Posted April 11, 2019 Share Posted April 11, 2019 hi I am trying to fit the rack for my side panniers but don't seem to be able to screw in the two front elan bolt into where they obviously go they only scew in a couple of threads if that looking up the hole it seems to have a bolt screwed in from the other side possibly holding the petrol tank on any ideas welcome cheers jem Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted April 11, 2019 Share Posted April 11, 2019 Is the bolt supposed to go all the way through and hold everything, even the fuel tank, in place? Are you sure you're trying to use the right bolts? Can we have any pictures?? Quote Link to comment Share on other sites More sharing options...
jem1 Posted April 11, 2019 Author Share Posted April 11, 2019 I have been using the bolts that came with the rack the other ones fit but both the front ones on each side don't it's very odd I am sure I have the right hols as everything lines up perfectly I am not athe home till Saturday but will post some pics then Quote Link to comment Share on other sites More sharing options...
Gerontious Posted April 11, 2019 Share Posted April 11, 2019 If this is for the genuine rack, for the BMW panniers then you need these:This has to be fitted first, if its not already been changed: Then this: Had you asked, I would have suggested you not bother with the Genuine BMW and gone for Givi instead. which is far better and a lot cheaper.As you do not need to touch the original 'luggage' rack at the rear of the bike. https://tinyurl.com/y5jhpefzGivi also produce an adapter so a top case can be used on the original 'luggage' rack. Quote Link to comment Share on other sites More sharing options...
jem1 Posted April 14, 2019 Author Share Posted April 14, 2019 It turns out the front of the mounting points the thread was stripped on both sides but half way through the thread was just blocked with rust/ dirt tapped them both out and all went together fine Quote Link to comment Share on other sites More sharing options...
