Staffy Posted April 9, 2018 Share Posted April 9, 2018 I've booked my theory test for the end of the month and after revising I'm quietly confident for that part. What I am nervous about is the hazard perception test. When I passed my car test in '97 I didn't have to do one, but after doing a few online practices I've noticed the window for scoring high points is quite narrow. Does anyone have any hints and tips?Thanks Quote Link to comment Share on other sites More sharing options...
Hoggs Posted April 9, 2018 Share Posted April 9, 2018 there's free practise videos to be found online OH I MISREAD YOUR POST TOTALLY Yes click when you see the hazard (fast moving car) click again when it gets close (not slowing down.... eep!) and click again when it's like right in your face. Don't wildly click and the computer seems to refuse to believe you can't see danger as far ahead as you can hence the few extra safety clicks needed good luck!! Quote Link to comment Share on other sites More sharing options...
Via Posted April 9, 2018 Share Posted April 9, 2018 As said click a few times but don't go mentalI also found that it won't register until it's an actual hazard so in a practice one two people walk behind a van but didn't score until they emerged in road which was frustratingI had same fears as you and with things like that in practice ones didn't help but on real thing I passed comfortably and they are all fairly obvious Quote Link to comment Share on other sites More sharing options...
geofferz Posted April 9, 2018 Share Posted April 9, 2018 Overclicking is quite hard. So for anything that looks suspicious just click, then when it develops, and develops again (and it's in your face). Most clips have 1 hazard, a couple of have 2 I think, so keep watching. Quote Link to comment Share on other sites More sharing options...
anth_85 Posted April 9, 2018 Share Posted April 9, 2018 I've booked my theory test for the end of the month and after revising I'm quietly confident for that part. What I am nervous about is the hazard perception test. When I passed my car test in '97 I didn't have to do one, but after doing a few online practices I've noticed the window for scoring high points is quite narrow. Does anyone have any hints and tips?Thanks I read it's a good idea to double click about half a second apart to make sure your not clicking slightly too early and scoring 0. I used that method, didnt get any overclicking warning and passed with 66/75. Quote Link to comment Share on other sites More sharing options...
Guest Posted April 9, 2018 Share Posted April 9, 2018 It's a stupid test but follow what people have said and you should be fine. The key bit is when the hazard develops not just when you see a potential hazard. There was a guy on here a while bike who threw his toys right out the pram at this test and decided he wouldn't ride a motorbike because of it or something stupid. Just don't be that man, Quote Link to comment Share on other sites More sharing options...
Staffy Posted April 9, 2018 Author Share Posted April 9, 2018 Thanks all for the advice. If I fail because of it I certainly won't give up, I'll use it as a practice and take what I've learnt into the retest. I'm looking forward to it, just a little nervous. I've got a couple of weeks before then so I'll continue with my research and hopefully all will be good.Thanks all. Quote Link to comment Share on other sites More sharing options...
Hoggs Posted April 9, 2018 Share Posted April 9, 2018 I feel i should also mention that I failed the first time! Nailed it the second time though Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted April 9, 2018 Share Posted April 9, 2018 The problem is the Hazard Perception test is primarily aimed at learner drivers/riders. As an experienced road user you should spot the hazard well before a learner would as you know from years of experience all the clues that lead up to a potential hazard. This means that you will usually click before the scoring window starts. As everyone has said about clicking a couple of times, do so. Click when you can see a hazard developing (experience) then click again maybe a second later (inexperience) Try it on the practice clips and see if your score improves.The best DVD to use is here. https://m.ebay.co.uk/itm/2018-Driving-Theory-Test-Hazard-CD-DVD-Official-Highway-Code-Book-L-/121056148533 When I was a Driving Instructor I advised all my pupils to buy this. Good luck. Quote Link to comment Share on other sites More sharing options...
Staffy Posted April 10, 2018 Author Share Posted April 10, 2018 Thanks for the link, that looks exactly what I need.Cheers Quote Link to comment Share on other sites More sharing options...
onesea Posted April 10, 2018 Share Posted April 10, 2018 I spent the money on an app and studied for theory and hazard in one go.... Worked for me and seems I would recommend, just look for best reviewed app.As others have said don't just click once if its a hazard, I did over click one scenario in my test (there where no hazards) and I still passed... Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted April 10, 2018 Share Posted April 10, 2018 everything is a hazard on a motorbike Quote Link to comment Share on other sites More sharing options...
phil4 Posted April 11, 2018 Share Posted April 11, 2018 When I did mine a couple of years back each clip had 1 and only - hazard, except for one “double hazard” clip.I fell into the trap of flagging potential hazards, the double tap saved me, but on one clip I over clicked and scored 0.It’s a bit tricky as you don’t score and can be penalised for clicking potential hazards, but equally it can be a bit late if you wait until it actually happens... and of course in hindsight it’s obvious.I still passed by a reasonable margin, so no great problems, just adopt the strategy mentioned and Practice a bit.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Flangie74 Posted April 12, 2018 Share Posted April 12, 2018 Many of the apps available still use old fuzzy video, however the test itself now uses only CGI which is much clearer and the hazards are now incredibly easy to spot compared to the old videos. It would be difficult to get full marks I think due to the timing you'd need to hit the '5 score' window every time, but if you have been driving for a long time you should have little problem passing (touch wood). In terms of clicks I did 5 steady ones (a bit faster than one per second) when I saw the hazard develop and that seemed to cover the scoring window for the most part, without triggering a too many clicks warning. Quote Link to comment Share on other sites More sharing options...
Staffy Posted April 12, 2018 Author Share Posted April 12, 2018 Many of the apps available still use old fuzzy video, however the test itself now uses only CGI which is much clearer and the hazards are now incredibly easy to spot compared to the old videos. It would be difficult to get full marks I think due to the timing you'd need to hit the '5 score' window every time, but if you have been driving for a long time you should have little problem passing (touch wood). In terms of clicks I did 5 steady ones (a bit faster than one per second) when I saw the hazard develop and that seemed to cover the scoring window for the most part, without triggering a too many clicks warning. Thanks, that is reassuring. Nervous, but strangely looking forward to it! Quote Link to comment Share on other sites More sharing options...
HomerPlata Posted April 12, 2018 Share Posted April 12, 2018 I got 90%+ in the hazard perception test, then got swiped by a car after 3 months riding. It's not an exact science Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted April 12, 2018 Share Posted April 12, 2018 yes it helps if you react to the hazards as well as perceive them. Quote Link to comment Share on other sites More sharing options...
HomerPlata Posted April 12, 2018 Share Posted April 12, 2018 yes it helps if you react to the hazards as well as perceive them. I did, I clicked my finger on my petrol tank a couple of times. The test is flawed. Quote Link to comment Share on other sites More sharing options...
Via Posted April 12, 2018 Share Posted April 12, 2018 yes it helps if you react to the hazards as well as perceive them. On my test I did nod off for a moment and just muttered to myself 'what an absolute twat' before I remembered I should be clicking. Quote Link to comment Share on other sites More sharing options...
Gavc88 Posted April 12, 2018 Share Posted April 12, 2018 On my first one (about 10 years ago) i got like 30/75Then on the one i did last year i got about 60/75. I get the impression that if i did it 5 times in a row with the same videos i would get varying results. Quote Link to comment Share on other sites More sharing options...
Staffy Posted April 27, 2018 Author Share Posted April 27, 2018 Did the theory and hazard perception test this morning and passed! I'm over the moon and pleased with my scores. Next step mod 1! Quote Link to comment Share on other sites More sharing options...
Via Posted April 27, 2018 Share Posted April 27, 2018 Nice one Quote Link to comment Share on other sites More sharing options...
Staffy Posted April 27, 2018 Author Share Posted April 27, 2018 Cheers mate Quote Link to comment Share on other sites More sharing options...
geofferz Posted April 27, 2018 Share Posted April 27, 2018 Good man Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted April 27, 2018 Share Posted April 27, 2018 Good news!One step closer to achieving your goal. If you think you've got a big smile on your face, wait till you get on the road with your first bike! Talking of bikes. Has anything taken your fancy? Quote Link to comment Share on other sites More sharing options...
