Joeman Posted March 30, 2017 Share Posted March 30, 2017 Lidl had oil change suction pumps on offer a few days ago. The idea is they suck the oil out of the dipstick tube on cars to save having to crawl underneath to pull the sumpplug.Anyone tried one on a motorcycle?? It would save people shearing sump bolts if they worked!! Quote Link to comment Share on other sites More sharing options...
Stu Posted March 30, 2017 Share Posted March 30, 2017 Just take a side cover off and lay the bike down Quote Link to comment Share on other sites More sharing options...
Mawsley Posted March 30, 2017 Share Posted March 30, 2017 Siphon it out. Can't see anything going wrong with that plan. Quote Link to comment Share on other sites More sharing options...
tuktuk Posted March 30, 2017 Share Posted March 30, 2017 Read about one of these not too long ago and the tube going through the dipstick hole was in 2 pieces. Got it snagged and the bottom half ended up stuck in the sump Im guessing alot of garages use these to save removing undertrays etc? Quote Link to comment Share on other sites More sharing options...
Westbeef Posted March 30, 2017 Share Posted March 30, 2017 Sounds like I could save a sump with this. Quote Link to comment Share on other sites More sharing options...
Baldrick Posted March 30, 2017 Share Posted March 30, 2017 I remember back in the 70's and early 80's petrol stations had machines that did this, a bit like the air compressors they have now, you put 50p in and it sucked the oil out from the dipstick tube, then you just filled it back up with oil from the petrol station.Dead quick and easy oil changes.Never tried it on my bike though.And yes, I realise my reminiscing in no way helps you in your quest, and for this I apologise unreservedly. Quote Link to comment Share on other sites More sharing options...
Joeman Posted March 30, 2017 Author Share Posted March 30, 2017 I remember back in the 70's and early 80's petrol stations had machines that did this, a bit like the air compressors they have now, you put 50p in and it sucked the oil out from the dipstick tube, then you just filled it back up with oil from the petrol station.Dead quick and easy oil changes.Never tried it on my bike though. In the USA they have drive through oil change shops... clearly people over there feel the need to change their oil more regularly than we do over here.If garages still had oil suction pumps it would be great!! Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted March 30, 2017 Share Posted March 30, 2017 I have a vacuum unit.Also a couple of vacuum bottles and some tubing.I feel an experiment coming on.... Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted March 30, 2017 Share Posted March 30, 2017 Suction pumps work well on cars if the dipstick tube goes all the way to the bottom of the sump.Unfortunatly on many it doesn't I tried using oneon my Mondeo and it only pulled 4,5litre out, when I do a oil chnage by the sump plug 6 litres ocmes out.On most bikes the oil filler has the dipstick in it. So you need to put a tube in here to suck the oil out. I had a look at my GSX600F engine, the sump pan is a long way from the filler on the clutch housing & much lower down.It doesn't look like I could get a tube to the bottom of the sump to get most of the oil out! Quote Link to comment Share on other sites More sharing options...
Stu Posted March 30, 2017 Share Posted March 30, 2017 You also need to think about surge guards that are fitted to some bikes Quote Link to comment Share on other sites More sharing options...
TimR Posted March 31, 2017 Share Posted March 31, 2017 And what removes all those lovely metal bits stuck on the magnetic sump plugs .... Old kwaks have dual level sumps so it would be a mission to make sure you got it all. Quote Link to comment Share on other sites More sharing options...
barker Posted March 31, 2017 Share Posted March 31, 2017 I was in lidi the other day and had the same idea as you, but after reading this im not going to bother with it will invest in a 17 mm spanner Quote Link to comment Share on other sites More sharing options...
cockercas Posted March 31, 2017 Share Posted March 31, 2017 You only need to remove the bellypan and undo the drain plug.Takes 2min and you get all the shit out Quote Link to comment Share on other sites More sharing options...
Stu Posted March 31, 2017 Share Posted March 31, 2017 You only need to remove the bellypan and undo the drain plug.Takes 2min and you get all the shit out I don't need to do that! I can do oil and filter without taking anything off Quote Link to comment Share on other sites More sharing options...
TimR Posted March 31, 2017 Share Posted March 31, 2017 You only need to remove the bellypan and undo the drain plug.Takes 2min and you get all the shit out I don't need to do that! I can do oil and filter without taking anything off And thank god for that ( his wife adds ) Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted March 31, 2017 Share Posted March 31, 2017 I tried it. It didn't work. Some nob stuck the clutch in the way. Quote Link to comment Share on other sites More sharing options...
fastbob Posted March 31, 2017 Share Posted March 31, 2017 And what removes all those lovely metal bits stuck on the magnetic sump plugs .... Old kwaks have dual level sumps so it would be a mission to make sure you got it all.Totally agree,daftest idea I've heard in ages. Quote Link to comment Share on other sites More sharing options...
Joeman Posted March 31, 2017 Author Share Posted March 31, 2017 And what removes all those lovely metal bits stuck on the magnetic sump plugs .... Old kwaks have dual level sumps so it would be a mission to make sure you got it all.Totally agree,daftest idea I've heard in ages. modern engines are mostly alloy, so how much use is a magnetic sump plug these days? whats it going to collect? Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted April 1, 2017 Share Posted April 1, 2017 I've used these on cars and providing you change the oil regularly and do it when the oil is warm they get as much out of the sump as dropping it via the drain plug. But I've yet to be convinced that they work on most bikes. Quote Link to comment Share on other sites More sharing options...
Tango Posted April 1, 2017 Share Posted April 1, 2017 And what removes all those lovely metal bits stuck on the magnetic sump plugs .... Old kwaks have dual level sumps so it would be a mission to make sure you got it all.Totally agree,daftest idea I've heard in ages. modern engines are mostly alloy, so how much use is a magnetic sump plug these days? whats it going to collect?Bits of bearings, cylinder liners, bits of gears, etc.......but ideally it shouldn't be collecting anything, if your engine is in good order...... Quote Link to comment Share on other sites More sharing options...
Joeman Posted April 1, 2017 Author Share Posted April 1, 2017 I've used these on cars and providing you change the oil regularly and do it when the oil is warm they get as much out of the sump as dropping it via the drain plug. But I've yet to be convinced that they work on most bikes.That's what i was thinking, and being so much more convenient than pulling the sump plug means you could change your oil much more frequently which would remove the sludge I'd there was any.. but as Mr Fro says, on bikes the clutch is probably in the way.. Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 1, 2017 Share Posted April 1, 2017 And what removes all those lovely metal bits stuck on the magnetic sump plugs .... Old kwaks have dual level sumps so it would be a mission to make sure you got it all.Totally agree,daftest idea I've heard in ages. modern engines are mostly alloy, so how much use is a magnetic sump plug these days? whats it going to collect?Modern engine cases are mostly alloy , cranks,gears and bearings are steel Quote Link to comment Share on other sites More sharing options...
Joeman Posted April 1, 2017 Author Share Posted April 1, 2017 I always thought they were mainly there to catch debris from the manufacturing process.. if you have bits of crank, bearing or gears coming off you have a bigger problems!!It all has to pass through the oil filter and with modern filter technology, can anything pass through the filter that shouldn't?Back in the olden days i could imagine filters weren't so efficient so magnetic plugs made more sense. Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 3, 2017 Share Posted April 3, 2017 I always thought they were mainly there to catch debris from the manufacturing process.. if you have bits of crank, bearing or gears coming off you have a bigger problems!!It all has to pass through the oil filter and with modern filter technology, can anything pass through the filter that shouldn't?Back in the olden days i could imagine filters weren't so efficient so magnetic plugs made more sense.All very good points but I think I will carry on dropping the oil out through the sump plug. If the worst happened and I stripped the thread then at least it's only the oil pan ( on most engines ) that would have to be replaced or machined. Also , as mentioned here, the clutch would be in the way on my bike. S Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted April 4, 2017 Share Posted April 4, 2017 Block & Tackle...Simply invert the bike and remove the filler cap! Quote Link to comment Share on other sites More sharing options...
