tacho xv535
fishermanferg
ive got a universal tacho that I would like to fit to my xv535 has anybody fitted one there was no wiring instructions it has five wires a long red one a long black one a short green one a short black one a short yellow /black one ,I'm sure the yellow black one is the signal wire that connects to the coil I'm not sure about the other wires any help appreciated
thanks for reply no name on tacho I managed to google the same one ,its Chinese and hopefully ive found how it is wired the long red and black are for the bulb I tried them across a battery and the tach o lit up ,the yellow back is the signal wire that you attatch to the coil negative side the other vtwo are power and ground ,I'm going to have a go tomorrow the coils are not that hard to get to ,ive changed them before , the signal wire on the xv535 is either orange for the rear cylinder or gray for the front ,will let you know how I get on ,you know what Chinese parts can be like
