Foxy Stoat seeks Pig Posted April 2, 2017 Share Posted April 2, 2017 I replaced my coolant last weekend. I filled up to the correct fill level on the reservoir. I've done about 100 miles tops this week and I checked the level earlier today. The reservoir was only 3/4 full. So I topped up again. Would the level have dropped as the coolant worked its way around water pump and radiator during the 100 miles I've done?? Certainly no leaking anywhere.Thanks Quote Link to comment Share on other sites More sharing options...
Stu Posted April 2, 2017 Share Posted April 2, 2017 you could have had an airlock in there Just keep an eye on it Quote Link to comment Share on other sites More sharing options...
Maxorama Posted April 2, 2017 Share Posted April 2, 2017 I've had a faulty water pump let coolant into the crank case, so it might be worth checking your engine oil - if its brown and smells sweet, with emulsified oil on the sight glass, that would be a sign of coolant in your oil. small leaks/cracks can close up by the time the engine is warm.is the bike over heating at all?to be fair its probs just a pocket of air as was suggested already Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted April 2, 2017 Author Share Posted April 2, 2017 I've had a faulty water pump let coolant into the crank case, so it might be worth checking your engine oil - if its brown and smells sweet, with emulsified oil on the sight glass, that would be a sign of coolant in your oil. small leaks/cracks can close up by the time the engine is warm.is the bike over heating at all?to be fair its probs just a pocket of air as was suggested already Oil is clean, that was changed as well. Bike not over heating. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted April 2, 2017 Author Share Posted April 2, 2017 you could have had an airlock in there Just keep an eye on it So as the level has a dropped does that suggest the airlock has gone?? I will keep an eye on it through the week. And now that lighter evenings have arrived it can tinker after work if needs be. Hopefully won't need to though. Quote Link to comment Share on other sites More sharing options...
Tango Posted April 2, 2017 Share Posted April 2, 2017 Chances are that you had some air trapped somewhere, which has now cleared.......or it's come out of the expansion tank overflow.......my Speedy is good at spitting excess coolant out the overflow pipe when he gets hot...... Quote Link to comment Share on other sites More sharing options...
Stu Posted April 2, 2017 Share Posted April 2, 2017 it suggests either some has leaked out or there was/is an airlock and space has been taken up by some in the reservoir it doesn't mean all of the airlock is out though As I said keep an eye on it If it keeps dropping then there is an issue somewhere I would have a few more rides first though It is pretty common for it to drop after a coolant change on some bikes Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted April 2, 2017 Author Share Posted April 2, 2017 Ok thanks all. I will see how it goes week. Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 3, 2017 Share Posted April 3, 2017 I replaced my coolant last weekend. I filled up to the correct fill level on the reservoir. I've done about 100 miles tops this week and I checked the level earlier today. The reservoir was only 3/4 full. So I topped up again. Would the level have dropped as the coolant worked its way around water pump and radiator during the 100 miles I've done?? Certainly no leaking anywhere.ThanksYou say that you have filled the reservoir but is it actually a reservoir and not an expansion tank. If I wanted to be sure that my cooling system was full I would fill to the top of the radiator cap. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted April 3, 2017 Author Share Posted April 3, 2017 The service manual suggests it's a reservoir not expansion tank. I also filled directly into the radiator and at that point the correct level was showing on the reservoir. I have checked after todays ride (20 miles) and all seems fine at the moment. Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 4, 2017 Share Posted April 4, 2017 The service manual suggests it's a reservoir not expansion tank. I also filled directly into the radiator and at that point the correct level was showing on the reservoir. I have checked after todays ride (20 miles) and all seems fine at the moment.Glad you got it sorted . This reservoir/expansion tank thing is a bit of a grey area.On both my bikes the tank is right at the back of the bike and connected by a long thin tube. This doesn't seem like a very good arrangement to me but I think it's because there isn't anywhere else to put it. Quote Link to comment Share on other sites More sharing options...
