barker Posted April 14, 2017 Share Posted April 14, 2017 my Honda xr125 ,has been behaving its self this last few weeks until yesterday when it decided to chuck petrol all over the garage floor , put new pipe on as the old one was split but it still does it once the petrol is turned, on once its started the leak stopsany ideas Quote Link to comment Share on other sites More sharing options...
Stu Posted April 14, 2017 Share Posted April 14, 2017 is it coming out the overflow on the carb? sounds like a stuck float valve in the carb Quote Link to comment Share on other sites More sharing options...
barker Posted April 14, 2017 Author Share Posted April 14, 2017 will have a closer look tomorrow must admit the carb was covered in petrol but that probably was the pipe Quote Link to comment Share on other sites More sharing options...
Tango Posted April 14, 2017 Share Posted April 14, 2017 Yep.....sounds like a stuck float in the carb...... Quote Link to comment Share on other sites More sharing options...
TimR Posted April 15, 2017 Share Posted April 15, 2017 Give the carb bowl a few gentle taps with hammer handle / screwdriver handle to see if this cures it ( can dislodge the piece of crud thats causing the float to stick / Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted April 15, 2017 Share Posted April 15, 2017 Give the carb bowl a few gentle taps with hammer handle / screwdriver handle to see if this cures it ( can dislodge the piece of crud thats causing the float to stick /Vigorously bouncing on the seat also does the trick some times. Quote Link to comment Share on other sites More sharing options...
barker Posted April 23, 2017 Author Share Posted April 23, 2017 float was sticking Quote Link to comment Share on other sites More sharing options...
