david5757 Posted April 17, 2017 Share Posted April 17, 2017 After changing my clutch plates, my lever was pretty loose, after adjusting it it would start and then stall.I tried to re adjust my slack al the way to the back at the bottom adjuster, it starts now but when putting it in 1st it would roll forward, what am i doing wrong? Quote Link to comment Share on other sites More sharing options...
Stu Posted April 17, 2017 Share Posted April 17, 2017 How much slack have you got at the lever before you can feel it pull on the clutch? Quote Link to comment Share on other sites More sharing options...
david5757 Posted April 17, 2017 Author Share Posted April 17, 2017 How much slack have you got at the lever before you can feel it pull on the clutch?About the same when it did worked, although it gets alot more stiff when almost pulled in al the wayVerstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Quote Link to comment Share on other sites More sharing options...
Stu Posted April 17, 2017 Share Posted April 17, 2017 Well if you are getting drag after changing the clutch plates you are either not getting enough pull on the clutch so you have too much slack or there is a problem in the clutch pack itself Quote Link to comment Share on other sites More sharing options...
david5757 Posted April 17, 2017 Author Share Posted April 17, 2017 Well if you are getting drag after changing the clutch plates you are either not getting enough pull on the clutch so you have too much slack or there is a problem in the clutch pack itselfI think its the clutch pack itself then, thanksVerstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Quote Link to comment Share on other sites More sharing options...
TimR Posted April 17, 2017 Share Posted April 17, 2017 Did you soak the clutch plates in oil ? Did you make sure the alternating pattern with clutch plates and pressure plates ? Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted April 17, 2017 Share Posted April 17, 2017 Have you followed the correct adjustment method. ON most bikes you slacken the cable right off.Then on many bikes (not all), there is an adjusting screw and locknut, undo the locknut, adjust screw out, then in until you feel resistance, backout 1/4 turn, tighten locknut. Now you can set the cable adjustment, at handlbar end fully screwed in, adjust at gearbox end untill end of lever has 15mm play (you have short levers so 10mm may be better). Quote Link to comment Share on other sites More sharing options...
Stu Posted April 17, 2017 Share Posted April 17, 2017 Have you followed the correct adjustment method. ON most bikes you slacken the cable right off.Then on many bikes (not all), there is an adjusting screw and locknut, undo the locknut, adjust screw out, then in until you feel resistance, backout 1/4 turn, tighten locknut. Now you can set the cable adjustment, at handlbar end fully screwed in, adjust at gearbox end untill end of lever has 15mm play (you have short levers so 10mm may be better). only on worm drive actuators and looking at the top pic its not a worm drive actuator Quote Link to comment Share on other sites More sharing options...
Tango Posted April 17, 2017 Share Posted April 17, 2017 Did you soak the clutch plates in oil ? Did you make sure the alternating pattern with clutch plates and pressure plates ?Yep......did you soak the plates in oil overnight before fitting them? Quote Link to comment Share on other sites More sharing options...
david5757 Posted April 18, 2017 Author Share Posted April 18, 2017 Did you soak the clutch plates in oil ? Did you make sure the alternating pattern with clutch plates and pressure plates ?Yep......did you soak the plates in oil overnight before fitting them?In did soak Them yeah for about 15 hours. Is also put the friction plates and steel plates alternating Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Quote Link to comment Share on other sites More sharing options...
david5757 Posted April 18, 2017 Author Share Posted April 18, 2017 Did you soak the clutch plates in oil ? Did you make sure the alternating pattern with clutch plates and pressure plates ?Yes Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Quote Link to comment Share on other sites More sharing options...
Tango Posted April 18, 2017 Share Posted April 18, 2017 That looks like a non-standard lever......have you tried it on 6?......maybe it's hitting the bars before the clutch is fully disengaged. ..... Quote Link to comment Share on other sites More sharing options...
david5757 Posted April 24, 2017 Author Share Posted April 24, 2017 Decided to give it another go, in the situation with these photos the bike wont start at all. When i put the adjuster all the way to the end (Bottom adjuster) it wil start but when putting it in first Gear it Will already start to roll forward. I also noticed that my cable is a little bit frayed near the handlebar, anyone know how to go from here? I think moving the Bottom adjuster more Will help but it is already at his maximum point. Quote Link to comment Share on other sites More sharing options...
Joeman Posted April 24, 2017 Share Posted April 24, 2017 In that photo the bottom adjuster isn't at the max adjustment? Quote Link to comment Share on other sites More sharing options...
david5757 Posted April 24, 2017 Author Share Posted April 24, 2017 In that photo the bottom adjuster isn't at the max adjustment?No i turned it back to see if that would workVerstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Quote Link to comment Share on other sites More sharing options...
Joeman Posted April 24, 2017 Share Posted April 24, 2017 Was it working ok before you messed with the clutch?Not changed another part? Quote Link to comment Share on other sites More sharing options...
david5757 Posted April 24, 2017 Author Share Posted April 24, 2017 Was it working ok before you messed with the clutch?Not changed another part?You mean before i changed clutch plates? Yes it didVerstuurd vanaf mijn ONEPLUS A3003 met Tapatalk Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 24, 2017 Share Posted April 24, 2017 In the second set of pictures you have even more slack than in the first so the clutch is going to drag even more. You don't want any slack at all because because taking up the slack is just a waste of lever movement. What you want is a kind of neutral state where cable is neither slack nor tight. If none of this works I would start over again and re fit the clutch making sure that every friction and steel plate is in the correct order and all other parts are correctly installed.A new cable definitely seems like a good idea if it's frayed it's going to snap soon anyway. Keep at it. Quote Link to comment Share on other sites More sharing options...
