Kraai Posted April 19, 2017 Share Posted April 19, 2017 Hello guys, I'm in a bit of a pickle and in way over my head and I need some advice.Bike: Yamaha YZF-R125Problem: Buggerd engine?So, a few weeks ago, my Yamaha with 11K on the clock ran into a problem, I was riding home and suddenly I lost all power from the engine ( I managed to keep it going by dropping it throw the gears) but then all the power came back (Just some crap going throw the carb I thought), okay, no problem, this happend a second time time, same as before power dropped, I dropped the gears, power came back, only this time , a noise came aswell, It's hard to pin point what the sound was, but it was kinda like a loud ticking noise, coming from the top end of the engine, (Tappets must be lose, I'll run it into the local garrage) , leave it with them they said, cue one week later, it's not the tappets.Turns out, the engine had seized (I did cheek the oil 2 days before the original problem all seamed fine to me), apparently the piston eye-let (you'll have to forgive me here) had seized to the piston, caused the piston to jump or something and dented the cam/ crank, (they showed me the damage and there was scuff marks on the cam? and engine cylinder aswell) , and they want to do a full engine re-build/ get a new engine.Now what I don't understand is, the engine was working about fine, no loss of power after this (apart from sometimes at idle it would stall) but the bike worked fine, apart from this noise, hell I even ridden it to the garage.So my question is I'm I being f**ked with?TL;DR Engine f**ked, but not f**ked, I'm I being conned? Quote Link to comment Share on other sites More sharing options...
Stu Posted April 19, 2017 Share Posted April 19, 2017 It could have been a hot seizure IE when the engine gets hot everything expands and seizes up or starts to seize up slowing down can be enough to loose that heat for it to start working again I have had this on a car when a head gasket went and it drank all its water Without seeing the engine its hard to say if you are getting screwed or not Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 19, 2017 Share Posted April 19, 2017 Exactly the same thing happened to a colleague of mine on a YBR 125 . Hate to have to say it but although it says Yamaha on the tank its actually made in China. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted April 19, 2017 Share Posted April 19, 2017 the 125 yamaha is known for seizing up as stu says normally heat seizure due to lack of oil rebuild or replace is the cure Quote Link to comment Share on other sites More sharing options...
Northern Biker Posted April 20, 2017 Share Posted April 20, 2017 Throw in a new (second hand maybe) engine yourself. Perfect opportunity to learn more about your bike. Quote Link to comment Share on other sites More sharing options...
Kraai Posted April 20, 2017 Author Share Posted April 20, 2017 Alright, thank you very much guys, sounds like I am not being conned and a bike can still work while still being f**ked, new engine inbound. Quote Link to comment Share on other sites More sharing options...
Northern Biker Posted April 21, 2017 Share Posted April 21, 2017 Having a go at fitting it yourself? Where are you from? Quote Link to comment Share on other sites More sharing options...
Joeman Posted April 21, 2017 Share Posted April 21, 2017 Add a drop of two stroke oil to your petrol to add a bit of extra lube .. it might prolong the engine life a little. Quote Link to comment Share on other sites More sharing options...
