barker Posted May 2, 2017 Share Posted May 2, 2017 as you probably know ive got a 03 Honda xr125 that's giving me a few problems the latest is its ratley from the top end, rides ok but I really want to sort it so over this summer I will put a 150 barrel in it, but I would like to get a new head or reconditioned one , there's no rush as ive got other bikes to rideany way does any one know were I can get a recon head from, nearer the south coast the better Quote Link to comment Share on other sites More sharing options...
Joeman Posted May 3, 2017 Share Posted May 3, 2017 If there is no rush, why not get the existing head rebuilt/reconditioned?Also won't the 150 kit need a larger head anyway? Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted May 3, 2017 Share Posted May 3, 2017 Top end 'rattle' can be down to a few things, none of which would require a new head (especially as it is 'running OK').If it was me, I'd strip it down from the top and check everything, replacing if worn, adjusting if not. New gaskets and rebuild.A 150 'upgrade' is not really worth the expense if the bike is just a bit 'ratley' (sic). Quote Link to comment Share on other sites More sharing options...
barker Posted May 3, 2017 Author Share Posted May 3, 2017 not looking for more speed just want to do the engine up ,so thought while im at it might as well fit a 150 barrel as it uses same head and carb, im in no rush with this job so I thought I would sound out your thoughtsif any one has done the same how much did it cost and was it worth it Quote Link to comment Share on other sites More sharing options...
Stu Posted May 3, 2017 Share Posted May 3, 2017 I hope you have done your test before doing a 150 conversion on it otherwise you are riding not in accordance to your licence But as is said above no new head needed just probably needs looking at Quote Link to comment Share on other sites More sharing options...
Tango Posted May 3, 2017 Share Posted May 3, 2017 Yeah....A 150cc kit could get you into trouble...... Quote Link to comment Share on other sites More sharing options...
barker Posted May 4, 2017 Author Share Posted May 4, 2017 passed my test years ago so no problem will inform insurance as well if I carry it out think I will strip it down first and have a look at whats worn out then decide what to do Quote Link to comment Share on other sites More sharing options...
Tango Posted May 4, 2017 Share Posted May 4, 2017 passed my test years ago so no problem will inform insurance as well if I carry it out think I will strip it down first and have a look at whats worn out then decide what to doAh.....fair enough, mate...... Yeah, give it a look at before buying bits for it......may be nothing...... Quote Link to comment Share on other sites More sharing options...
barker Posted May 17, 2017 Author Share Posted May 17, 2017 stripped the barrel and head cant see anything wrong with any of it drained the oil it was thin black but no metal fragments in it the oil filter was fairly clogged up so cleaned it out and pui it backfound a firm who does the barrel for 129 with all the gaskets recon heads 55 giving it some thought over the next few weeksif its not the head that's rattling got any ideas as to what else would cause this Quote Link to comment Share on other sites More sharing options...
barker Posted June 21, 2017 Author Share Posted June 21, 2017 well I went for the 150 barrel and recon head . fitted it yesterday this morning it ran for the first time sounds ok no rattles or knocks so its fineone thing that had me worried was while the engine was out I could not change gear it just went from 2nd 3rd but no further seems fine now its runningonce the heat wave passes I will get it out on the road , will have to run it in .with a top end rebuild will it need 500 mile run in Quote Link to comment Share on other sites More sharing options...
