funinacup Posted June 4, 2017 Share Posted June 4, 2017 Hi guysCame out to find the bikes wheel facing straight and steering lock been forced round. Can't turn the key in the ignition now and I'm a bit stumped. Any ideas? Bike is a 2008 Bandit 1250. Thanks Michael Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
funinacup Posted June 4, 2017 Author Share Posted June 4, 2017 Managed to wiggle the key enough and get it to turn, but the key is going further than usual in both directions and the ignition doesn't come on in any position. I need to find out whether or not the battery is flat, but when I turn my heated grips on the display lights up so I'm assuming it's not so flat that the clocks wouldn't come on... Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Stu Posted June 4, 2017 Share Posted June 4, 2017 Have a look to see if any wiring has been snipped or pulled etc Quote Link to comment Share on other sites More sharing options...
funinacup Posted June 4, 2017 Author Share Posted June 4, 2017 Does anyone know if the steering lock pin cuts power to the ignition when it's in use? It's currently jammed in the lock position so I think that may be causing it to not power up when I turn the key.Having it recovered to a garage tomorrow hopefully so will see what they say, but expecting a big bill Quote Link to comment Share on other sites More sharing options...
raesewell Posted June 4, 2017 Share Posted June 4, 2017 Just out of interest, did you have any other locks or security devices on the bike? Quote Link to comment Share on other sites More sharing options...
TimR Posted June 4, 2017 Share Posted June 4, 2017 That frame lock is now f**ked .... Possibly the switch contacts have been dislodged / broken and causing cross contacts ..look at the bottom of the ign switch there should be a section where the wires go into it that unscrews and houses the actual switch contacts . Quote Link to comment Share on other sites More sharing options...
funinacup Posted June 4, 2017 Author Share Posted June 4, 2017 Just out of interest, did you have any other locks or security devices on the bike?Yeah, Oxford chain and disc lock. Nothing else seems damaged but the top yoke has a huge crack in it where they've levered the bars round. Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
raesewell Posted June 4, 2017 Share Posted June 4, 2017 Makes you wonder why they would break the steering lock with other locks in place. Quote Link to comment Share on other sites More sharing options...
funinacup Posted June 6, 2017 Author Share Posted June 6, 2017 Update: spoke to the garage (Saltire Motorcycles in Edinburgh) and they've advised it will need a new ignition barrel (£170) top yoke (£220 but got one used for £40) and a couple hours labour (£65/hr) so not a cheap repair. Scumbags (the thieves!). Saltire have been super helpful in allowing me to have the bike taken there even though they're slammed at the minute and don't really want extra bikes knocking around, but advised me to get it off the street as it was probably a target for another night now. ----2008 Bandit 1250 Quote Link to comment Share on other sites More sharing options...
Jacobyte Posted June 9, 2017 Share Posted June 9, 2017 Hope it works out for you. Saltire, a trustworthy bunch and always helpful. Got my bike from them too. Quote Link to comment Share on other sites More sharing options...
funinacup Posted June 10, 2017 Author Share Posted June 10, 2017 Picked up a second hand top yoke and dropped it off to Saltire today. Ignition barrel is in stock now and bike should be ready on Tuesday! ----2008 Bandit 1250 Quote Link to comment Share on other sites More sharing options...
Christopher Posted May 18, 2022 Share Posted May 18, 2022 Hi,my steering lock as been snapped, can't turn key,it's an aprilla 125sr gt.how much is going to cost to repair.thanks Quote Link to comment Share on other sites More sharing options...
