Jake.southwick Posted June 13, 2017 Share Posted June 13, 2017 Hi, so about a week ago I took my kawasaki kh 125 out to work and on the way back was hit by some heavy rain, ended up having to push the bike home as it stopped starting after a while, it would run for a bit then lose power and cut out and so on until it finally stopped for good. I found the problem( or so i thought) as some water had gotten into the fuel and into the carburetor so i drained the tank and cleaned the carb and put new fuel it, the bike still wouldnt start when I kick it over and there is a ticking/knocking noise coming from the engine. I have checked all the ignition coil, air filter and spark which are all good, I'm fairly new to bikes and don't have a clue what the noise is and why it isn't starting, anyone have any idea?!? Thank you. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2017 Share Posted June 13, 2017 Time for a compression test Quote Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2017 Share Posted June 13, 2017 PS: put a link to your previous thread in here because it contains information that is relevant to your problem. A doctor can't diagnose you if you only tell him half the symptoms. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2017 Share Posted June 13, 2017 PS: put a link to your previous thread in here because it contains information that is relevant to your problem. A doctor can't diagnose you if you only tell him half the symptoms. https://www.themotorbikeforum.co.uk/viewtopic.php?f=5&t=63964 Quote Link to comment Share on other sites More sharing options...
Jake.southwick Posted June 13, 2017 Author Share Posted June 13, 2017 thanks for linking!! I put my finger over the spark plug hole and it was just about blowing it off, I don't actually have a compression gauge to fully test it though Quote Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2017 Share Posted June 13, 2017 Where in the country are you? Quote Link to comment Share on other sites More sharing options...
Jake.southwick Posted June 13, 2017 Author Share Posted June 13, 2017 Suffolk Quote Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2017 Share Posted June 13, 2017 Bit far for you to borrow my compression tester Quote Link to comment Share on other sites More sharing options...
Jake.southwick Posted June 13, 2017 Author Share Posted June 13, 2017 might be able to get one from a frined dthank you though mate, any suggestions if it doesnt happen to be compression? Quote Link to comment Share on other sites More sharing options...
rennie Posted June 13, 2017 Share Posted June 13, 2017 I think it's more likely to be wet electrics!old 2 strokes don't like rain! Take the plug(s) out and see if you're getting a spark Quote Link to comment Share on other sites More sharing options...
