Dynamo_Delboy Posted June 14, 2017 Share Posted June 14, 2017 Hi all seem to be having a problem with downshiftinh on my 1989 ZX10.When going down the box sometimes im having to push the gear lever 2,3 sometimes 4 times to get it into gear.Its fine going up the gears.Any ideas what the problem could be?Thanks in advance Quote Link to comment Share on other sites More sharing options...
Stu Posted June 15, 2017 Share Posted June 15, 2017 It could be anything from a sticking gear lever to a knackered gearbox! Start with the easiest! Strip and clean the gear lever pivots and make sure its not sticking Quote Link to comment Share on other sites More sharing options...
Guest Posted June 15, 2017 Share Posted June 15, 2017 Make sure it's correctly adjusted too. I had problems changing up on an ER6, turned out that it was because my new boots were stiffer and I wasn't letting it disengage properly after the previous change. Adjusted the lever up a bit and problem solved. Obviously not quite the same thing but worth a look Quote Link to comment Share on other sites More sharing options...
