Davidmo3 Posted June 21, 2017 Share Posted June 21, 2017 hello guys I have a Suzuki intruder vl 125, been having a bit of trouble, it starts ok but sometimes sounds a bit low so have to rev it really high then it starts popping and black smoke comes out then it works fine, also it I have to keep revving it for it to stay running, please let me know if anyone knows anything, thanks people Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted June 22, 2017 Share Posted June 22, 2017 Sounds like it's running rich to me. Popping is unburned fuel igniting in the exhaust, black smoke is classic sign of rich mix, poor idle is also a sign of rich mix.It will pull ok on full throttle once the rpm rises as the engine will sucking in enough air for the rich mix. Quote Link to comment Share on other sites More sharing options...
Westbeef Posted June 22, 2017 Share Posted June 22, 2017 Mine did this when running rich, wasn't even a nice pop on the overrun either. Just sounded like an old shitty car Mine was caused by me doing something dumb with the battery, so I probably can't help you. - Unless you've messed with the battery recently, then just check where the wires are Quote Link to comment Share on other sites More sharing options...
TimR Posted June 22, 2017 Share Posted June 22, 2017 Check the air filter is clean Check the choke is operating properlyCheck the idle speed compared to the owners manual and adjust accordingly . Quote Link to comment Share on other sites More sharing options...
