Davidmo3 Posted June 26, 2017 Share Posted June 26, 2017 Hi guys just tried to ride home and the bike goes into gear two then cuts out, popping from the exhaust and sounding off Quote Link to comment Share on other sites More sharing options...
bonio Posted June 26, 2017 Share Posted June 26, 2017 I've only got silly questions to offer: enough fuel in the tank? is the fuel supply switch off? Quote Link to comment Share on other sites More sharing options...
Davidmo3 Posted June 26, 2017 Author Share Posted June 26, 2017 I've only got silly questions to offer: enough fuel in the tank? is the fuel supply switch off? Tank is pretty much full and I put it on reserve and still no luck Quote Link to comment Share on other sites More sharing options...
Westbeef Posted June 26, 2017 Share Posted June 26, 2017 Didn't you have problems with it running rich? Has that been sorted yet? Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted June 26, 2017 Share Posted June 26, 2017 Is this the same one that worked after you disconnected an additional brake light?And you'd changed the carb settings?If you've made it too rich then popping in the exhaust sounds like unburnt fuel getting past the valves - whip the plugs out again and see what they look like. Quote Link to comment Share on other sites More sharing options...
Davidmo3 Posted June 26, 2017 Author Share Posted June 26, 2017 Is this the same one that worked after you disconnected an additional brake light?And you'd changed the carb settings?If you've made it too rich then popping in the exhaust sounds like unburnt fuel getting past the valves - whip the plugs out again and see what they look like. I changed the settings and the sparks now this has started, it's one problem after another since I got this from the motorcycle shop near mine, every time I take it back to the garage I seem to have another problem about a week later, feel like they are having me over Quote Link to comment Share on other sites More sharing options...
