Guest Posted August 1, 2017 Share Posted August 1, 2017 Just acquired a CG 125 2001 modelI'm inspecting it all at the minute and I turned the flywheel by hand and now I can't roll the bike as it feels stuck. With a hard push it will roll but then stops again like the flywheel is strugglingIt's exactly the same when I try to do the kick start, really hard to push down then it releases and then it's hard again Tried to explain as best I can, do I need to re-position the flywheel it isn't it in fear or something The problem I have at the minute is that it's completely dead and I've tried charging battery and it's still dead so I can tell if it's in neautral or not Really need some help-thanks everyone Quote Link to comment Share on other sites More sharing options...
Westbeef Posted August 1, 2017 Share Posted August 1, 2017 You paid £150, it wont bump start and you can't turn it over by hand. I'm having a wild guess at something's seized or it's stuck in gear, but then I know nothing. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2017 Share Posted August 1, 2017 WHAt do you mean turn it over by hand-I can turn the flywheel with no issues Quote Link to comment Share on other sites More sharing options...
Adam Posted August 1, 2017 Share Posted August 1, 2017 Make sure it's in neutral, it should be half a click up from 1st gear so between 1st and 2nd. Or you can try holding the clutch in and give it a kick. It would also help if you charged the battery or replaced it. Quote Link to comment Share on other sites More sharing options...
Westbeef Posted August 1, 2017 Share Posted August 1, 2017 With a hard push it will roll but then stops again like the flywheel is struggling I can turn the flywheel with no issues You said you turned it once by hand then it started struggling, does the flywheel still rotate freely? Quote Link to comment Share on other sites More sharing options...
Guest Posted August 1, 2017 Share Posted August 1, 2017 Yeah I've sorted now and got it all up and running. Just need to figure out why it's stalling when I put it in 1st whichever I think is due to it being stood for years and the plates stickingHopefully an oil change and a bit of running will sort it Quote Link to comment Share on other sites More sharing options...
RantMachine Posted August 1, 2017 Share Posted August 1, 2017 WELP all of those threads were pointless Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted August 1, 2017 Share Posted August 1, 2017 Is this another "professional" build? Quote Link to comment Share on other sites More sharing options...
Northern Biker Posted August 3, 2017 Share Posted August 3, 2017 Were you trying to start it in gear then? [emoji57] Quote Link to comment Share on other sites More sharing options...
Westbeef Posted August 4, 2017 Share Posted August 4, 2017 Then was it cutting out cause you kicked it into gear on the side stand? Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 7, 2017 Share Posted August 7, 2017 WHAt do you mean turn it over by hand-I can turn the flywheel with no issues You must have strong hands then unless the spark plug is out . Quote Link to comment Share on other sites More sharing options...
