Guest Posted August 1, 2017 Share Posted August 1, 2017 So I bought a bike that's been sat for 4 years and I got it to start on 4th kick and she idles decent considering but as soon as I pull the clutch in and kick down to 1st it stalls Any ideas what this could be It's. Honda CG 125 2001 Quote Link to comment Share on other sites More sharing options...
RantMachine Posted August 1, 2017 Share Posted August 1, 2017 Clutch would be my first guess. Is it actuating properly?Also - be a lot easier to help with all these questions if you kept them in a single thread instead of starting a new one for every single issue Quote Link to comment Share on other sites More sharing options...
OhJay Posted August 1, 2017 Share Posted August 1, 2017 Side stand switch not working properly so it constantly thinks the side stand is down? Quote Link to comment Share on other sites More sharing options...
Northern Biker Posted August 3, 2017 Share Posted August 3, 2017 Yep, side stand switch if it has one. Disconnect it and join the wires together to rule it out. Or maybe being stood so long the clutch plates are stuck together? Quote Link to comment Share on other sites More sharing options...
RantMachine Posted August 4, 2017 Share Posted August 4, 2017 I think clutch plates is the current theory, but he hasn't posted since saying he was going to give that a look.£5 says there was an ancient Sumerian sealed away inside the clutch cover and he's now searching the earth for the Necronomicon in a state of snarky undeath. Quote Link to comment Share on other sites More sharing options...
Northern Biker Posted August 4, 2017 Share Posted August 4, 2017 £5 says there was an ancient Sumerian sealed away inside the clutch cover and he's now searching the earth for the Necronomicon in a state of snarky undeath. That makes total sense, good shout.Bet he hadn't thought of that! Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 4, 2017 Share Posted August 4, 2017 So I bought a bike that's been sat for 4 years and I got it to start on 4th kick and she idles decent considering but as soon as I pull the clutch in and kick down to 1st it stalls Any ideas what this could be It's. Honda CG 125 2001 Does it cut out the instant you select first gear or does it falter and stall when you let out the clutch and try to pull away ? I reckon the clutch is stuck together.What happens if the back wheel is off the ground? Quote Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2017 Share Posted August 6, 2017 I've sorted it now, cleaned all the clutch plates adjusted clutch and it goes into 1st like normal nowNext job is cleaning the carb out and then finding the right jets for a pod filter Quote Link to comment Share on other sites More sharing options...
fastbob Posted August 7, 2017 Share Posted August 7, 2017 I've sorted it now, cleaned all the clutch plates adjusted clutch and it goes into 1st like normal nowNext job is cleaning the carb out and then finding the right jets for a pod filter So did you find everyone's suggestions and advice useful or would you have figured it out for yourself ? Quote Link to comment Share on other sites More sharing options...
Guest Posted August 7, 2017 Share Posted August 7, 2017 All suggestions were much appreciated. My first thought was sticking clutch due to length it had been stood but I also looked into kickstand switch but I haven't got one Quote Link to comment Share on other sites More sharing options...
Northern Biker Posted August 7, 2017 Share Posted August 7, 2017 Glad it's sorted now mate. Quote Link to comment Share on other sites More sharing options...
