mpl Posted August 8, 2017 Share Posted August 8, 2017 Recently changed my bike and now have a BMW F800GT. Test ride and ride home seemed ok suspension wise. Played around with ESA settings and felt I could notice a slight difference between the three modes but tended to stick to "Normal".On my first ride out I was on the A10 Ely bypass and it was awful, really uncomfortable and bouncing off the seat somewhat. I experienced it to a lesser extent on my previous bike but this felt far worse. Bumps on other roads were sometimes equally horrible. Reading the manual it suggests with one up and no luggage decreasing the preload to it's lowest setting (Turn the adjuster as far asit will go counter-clockwise(One-up without luggage)). It's seems equally as bad if not worse! It feels like the rear wheel is actually leaving the road and I'm sure there has been a clunk (bottoming out?). Do I need to increase the preload? I feel that would make the suspension harder and the situation worse though.Any advice would be most welcomed. If it's makes any difference I weigh about 11.5 stone (73kg) so I'm not a heavy bugger weighing the bike down! Quote Link to comment Share on other sites More sharing options...
exportmanuk Posted August 8, 2017 Share Posted August 8, 2017 I would increase the pre-load one click at a time go and ride then repeat until you find something comfortable, but is sounds more like the damping thats the problem. The damping is to stiff dont know if it can be adjusted on your bike but I;m sure someone will be along to give advice. Quote Link to comment Share on other sites More sharing options...
mpl Posted August 8, 2017 Author Share Posted August 8, 2017 It can't as it has ESA. Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 8, 2017 Share Posted August 8, 2017 So you can't manually adjust the damping? Quote Link to comment Share on other sites More sharing options...
bonio Posted August 8, 2017 Share Posted August 8, 2017 Don't sound right to me. I'd take it back to the dealer and politely tell him to fix it. Quote Link to comment Share on other sites More sharing options...
bonio Posted August 8, 2017 Share Posted August 8, 2017 Oh noes. I've just looked back and seen you got it in Guildford. Was it from a dealer or private sale? Quote Link to comment Share on other sites More sharing options...
mpl Posted August 9, 2017 Author Share Posted August 9, 2017 From a dealer. Only done about 300 miles since getting it and only 1800 on clock. If there are problems this early I'll be well ticked off! I'll experiment with the preload and see if it makes any difference Quote Link to comment Share on other sites More sharing options...
mpl Posted August 9, 2017 Author Share Posted August 9, 2017 So you can't manually adjust the damping?Nope. As I said it has electronic suspension. Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 9, 2017 Share Posted August 9, 2017 No, you said it had ESA. Why would I know what that means? Anyway, there's your problem. Quote Link to comment Share on other sites More sharing options...
mpl Posted August 9, 2017 Author Share Posted August 9, 2017 Sorry, working on the obvious assumption that people would know what that stood for. Quote Link to comment Share on other sites More sharing options...
Stu Posted August 9, 2017 Share Posted August 9, 2017 Sorry, working on the obvious assumption that people would know what that stood for. Most of us do and if we don't then most find out for ourselves I would start with setting the preload to give as close to about 30mm of rider sag as possible then bounce the bike and see how if feels then adjust the damping throughout the full range (soft/hard) and bounce between each setting to see if there is a difference just to make sure the suspension is actually changing when its adjusted you should see a difference between max and min damping if not then you may have a problem if all appears to adjust then keep playing with the damping till it feels right I know some bikes can be a twat to set up Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 9, 2017 Share Posted August 9, 2017 I must have missed something. How many bikes have ESA? Quote Link to comment Share on other sites More sharing options...
Stu Posted August 9, 2017 Share Posted August 9, 2017 I must have missed something. How many bikes have ESA? Loads!! You need to move with the times! According to Ploss, 90 percent of BMW’s motorcycle buyers opt for ESA, http://www.cycleworld.com/2013/03/14/bmw-dynamic-electronic-suspension-adjustment-explained Quote Link to comment Share on other sites More sharing options...
JRH Posted August 9, 2017 Share Posted August 9, 2017 ESAEuropean space agencyEmployment and support allowanceNAHBMW suspension obviously. not Quote Link to comment Share on other sites More sharing options...
Gerontious Posted August 9, 2017 Share Posted August 9, 2017 ESAElectronic Suspension Adjustment. (obviously) Quote Link to comment Share on other sites More sharing options...
JRH Posted August 9, 2017 Share Posted August 9, 2017 Not at the top of Google Quote Link to comment Share on other sites More sharing options...
Gerontious Posted August 9, 2017 Share Posted August 9, 2017 indeed. Neither of my bikes have it.. and Im rather pleased about that.People generally rave about it until it goes wrong.. and then they get a quote and fall to the floor and foam at the mouth (a bit)particularly if they don't have a warranty.. from new or extended. Quote Link to comment Share on other sites More sharing options...
JRH Posted August 9, 2017 Share Posted August 9, 2017 NahTry goggling ESA. Quote Link to comment Share on other sites More sharing options...
Joeman Posted August 9, 2017 Share Posted August 9, 2017 ESA is old school now, DDC is the new kid on the block! Quote Link to comment Share on other sites More sharing options...
JRH Posted August 9, 2017 Share Posted August 9, 2017 I'll be diligent and check that out. Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 9, 2017 Share Posted August 9, 2017 Think I'll stick to adjusting damping myself. Less to go wrong. Quote Link to comment Share on other sites More sharing options...
Mawsley Posted August 9, 2017 Share Posted August 9, 2017 I bloody hate technology. People are only buying it because it's being lumped on the cost of their never-never. If I want to monitor my tyre pressure - I measure my tyre pressure. If I want rain mode - I ride slower. And why does anybody ever need 200 suspension measurements per second? Fat bloke, luggage, preload, job bloody done.Gah. Bloody technology.*shakes fist at cloud* Quote Link to comment Share on other sites More sharing options...
bonio Posted August 9, 2017 Share Posted August 9, 2017 I bloody hate technology. People are only buying it because it's being lumped on the cost of their never-never. If I want to monitor my tyre pressure - I measure my tyre pressure. If I want rain mode - I ride slower. And why does anybody ever need 200 suspension measurements per second? Fat bloke, luggage, preload, job bloody done.Gah. Bloody technology.*shakes fist at cloud* Having a good day, Dave? Quote Link to comment Share on other sites More sharing options...
Mawsley Posted August 10, 2017 Share Posted August 10, 2017 Having a good day, Dave? A succession of power cuts - I need an indie power supply for the computer.But I really do hate the way bikes are being designed so that you have to have them sorted at the dealers and not at the roadside. It's all guff and nonsense. (Today's excuse is sleep deprivation) Quote Link to comment Share on other sites More sharing options...
