WinstonR Posted August 19, 2017 Share Posted August 19, 2017 Ok, so I have been having a difficult time with the bike of late. I cannot get it to start. It will turn over no problem but will not start and won't bump start.I am getting fuel but no spark. The only thing I can go by is the error code which the bike provides. It only gives me one error code which is 18: cam pulse generator (CPG). I replaced this with a known working part but still no luck. I then ran a cable directly from the CPG to the ECU but still nothing. I took out my multimeter and checked to see if it was registering as a circuit but it wasn't. Therefore I appear to be getting no circuit between the CPG and the ECU. I have no idea why. I don't know how to resolve this, perhaps the ECU needs replaced?I have spent so much time on this and have pretty much missed out on the summer for riding. I have listed the bike on gumtree as spares or repair because I just cannot fathom the energy to spend any more time on it.If anyone has any advice on sorting this issue please let me know. Otherwise it's yours for £1200: https://www.gumtree.com/p/honda-motorbikes/honda-cbr-600-f-sport/1262464690. Quote Link to comment Share on other sites More sharing options...
bonio Posted August 19, 2017 Share Posted August 19, 2017 Oh no that sucks. That's really bad luck Sorry no wise advice from me except you'd do better to start a new thread with a title like "Help Help Bike Wont Start" as you might get more people looking at it than sticking it on the back of this thread. Quote Link to comment Share on other sites More sharing options...
Hoggs Posted August 19, 2017 Share Posted August 19, 2017 i haz moved hopefully our electronic wizards will along soon Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted August 19, 2017 Share Posted August 19, 2017 Couple of ideas:Have you checked the CPG wires individually i.e. between the ECU and the unit?Have you checked the signal from the CPG? If you've got a snazzy multi-meter with max/min you can connect it directly to the CPG and crank the engine - you should be able to find values in your service book. Otherwise stick the multi-meter on AC - if the value jumps about then it's likely working.If the CPG value is static then have a look at it's position - your manual should give you tolerance from the rotor.Failing that, I highly recommend Ignitech fully programmable ECU. Quote Link to comment Share on other sites More sharing options...
