Bike bogging (derbi)
Toppingcat
Hi i have just bought a 50cc derbi senda sm xtreme 2008 model. when i bought it there were a few problems such as exhaust leaking, air filter being in pieces and jets were too big (82). i put on a "big one" aftermarket exhaust and downjetted to 72.The guy i bought it from said that he had recently had a top end rebuild on the bike. when you get up to about 35mph it bogs out, it also sometimes has trouble starting up.any advice on how to fix this will be much appreciated
im not entirely sure what the standard is i think it is 68 but with the aftermarket jet i thought up jetting was the right thing to do, i do have a rev counter but it dosent work properly it sometimes works sometimes dosent im not sure why
  • 4 weeks later...
Those Dell'Orto PHVA 17.5 carbs are an atomiser / needle taper sensitivity nightmare. Also' the auto vacuum fuel tap diaphragm brakes and starves the engine of fuel.
Here's a few part numbers..
Derbi 00H00404181
Polini 201.1700
Polini 343.0009
Polini 343.0023
Polini 372.0004
Polini 370.0002
Adjust the oil injection pump nut to its maximum adjustment..
http://www.polini.com/wp-content/uploads/2016/05/cp_polini2ing.jpghttp://www.polini.com/wp-content/uploads/2016/05/cp_polini6ing.jpg
Slice those 2 pointy bits off the manifold rubber so the Polini carb fits properly..
Leave the needle clip on stock setting (middle notch)
Use pilot jet size (49)
Turn air screw fully in. Unscrew anticlockwise by 1 1/2 turns
Set the throttle stop screw so the engine stalls within 20 seconds
HFFS (How far from 4 stroking)
Most important rule: Don't inspect spark plug porcelain color. Leave that plug in the cylinder head.
Start the main jet rich (94). It'll fire on every 4th cycle at full throttle. Lower the main jet number 1 increment each time until it stops 4 stroking.
The engine should 4 stroke slightly under little engine loads around 1/4 throttle. If it 4 strokes like mad, lift the throttle needle clip to the 2nd notch.
https://www.youtube.com/watch?v=PZnRhJocqCQ
  • 2 months later...
hey sorry i completely forgot about this forum :) i actually got a polini carb about a week ago and fitted it as the phva was leaking anyway, just wanted to thankyou for your reply i did cut those bits off the manifold and im glad it was the right thing to do thankyou very much for the reply and sorry for the late reply :)
