crow95 Posted October 3, 2017 Share Posted October 3, 2017 help bike won't run properlyOk guys your my last resort I have a cbr125r 04 which was great for at least 4 months the last 2 have been hell so from the beginning I wanted to clean my tank stupily washing it with water and dropping some plastic into it I had filled the carb with gunk she wouldn't start and i had blown my fuses from fitting a new light so it all went wrong any how after cleaning the carb 5 times and buying new diaphrams I still has no luck a new spark plug soleniod feul tap and hoses was my next order still no luck so I decided to start again cleaned the carb engine has air fuel and spark and a lovely start roar now I thought brilliant it idles fine aswell I thought ok let's get that battery charged up didnt keep charge so new battery came and it held I was happy anyhow so I goes to pull away bike moves big smiles all around gets about 10 secs goes to open throttle some more and she bogs down pulls in clutch catches her and tried again same problem she won't pull away properly as soon as engine picks up she wants to stop help please I'm gonna try this or garage her it's a last resort help a fellow biker out Quote Link to comment Share on other sites More sharing options...
Tango Posted October 3, 2017 Share Posted October 3, 2017 Welcome to TMBF mate. . . . . pop over to the Newbies section and introduce yourself to the guys when you can. ..... So, when you rebuilt the carb did you set the needle height correctly.....and is the float set correctly too.......sounds like fuel starvation ......maybe blocked main jet too..... Quote Link to comment Share on other sites More sharing options...
crow95 Posted October 4, 2017 Author Share Posted October 4, 2017 I put the needle in the slot on the float not sure if that's right though but when I move the float the needle does rise and lower accordingly Quote Link to comment Share on other sites More sharing options...
taylordouglas203 Posted October 4, 2017 Share Posted October 4, 2017 help bike won't run properlyOk guys your my last resort I have a cbr125r 04 which was great for at least 4 months the last 2 have been hell so from the beginning I wanted to clean my tank stupily washing it with water and dropping some plastic into it I had filled the carb with gunk she wouldn't start and i had blown my fuses from fitting a new light so it all went wrong any how after cleaning the carb 5 times and buying new diaphrams I still has no luck a new spark plug soleniod feul tap and hoses was my next order still no luck so I decided to start again cleaned the carb engine has air fuel and spark and a lovely start roar now I thought brilliant it idles fine aswell I thought ok let's get that battery charged up didnt keep charge so new battery came and it held I was happy anyhow so I goes to pull away bike moves big smiles all around gets about 10 secs goes to open throttle some more and she bogs down pulls in clutch catches her and tried again same problem she won't pull away properly as soon as engine picks up she wants to stop help please I'm gonna try this or garage her it's a last resort help a fellow biker out Make sure that all tubes and pipes are air tight, as there is a chance you are pulling too much air from somewhere, giving you a weak mixture.Sent from my SM-J510FN using Tapatalk Quote Link to comment Share on other sites More sharing options...
