125cc 4 stroke valve stem seals
lyncho1983
Morning all,
I was wondering if anyone had a guide on how to replace the valve stem oil seals on a 125cc 4 stroke.
Mine is smoking a lot on start up and I need to replace them. the bike I have is a tw125 but I would imagine a guide/diy on another bike with the same size engine wont be too different.
thanks in advance
darren
Remove head, cam and valves. Pull seals off with long nose pliers. Push new seals on with a thumb. While head stripped, have valve seats and valve faces refaced for more power. Clean ports with rotary wire brushes. Easy job. Where are you based?
thanks for the replies guys.
I don't suppose anyone has a step by step guide on this do they? im mechanically minded when it comes to cars so wont have any issues doing the job myself but with motorbikes I don't really know where to start.
thanks
darren
Ive just done this job on my bike .....took me 4 hours .(with head off and on desk).JUST removing valves and adding new seals.....but that was with 16 valves
A single cylinder (2 valve??) will be fast and easy compared
You are gonna need a valve spring compressor and valve grinding kit...........you will be able to get away without grinding valves BUT
as said it will increase your compression sealing and directly increase power IF its needed to be done...........and seeing the age of your bike I would say you will benefit from it
you Will need timing instructions ....haynes will have all the info you need
(if you feel resistance when turning over engine by hand STOP and recheck timing)
you "May" need a fresh head gasket.....Again a good clean and possibly a light spray of copper coat will probably work Ok on a 125
If you decide to change head gasket look to see if Cometic do one for your bike......this will increase your compression a tad....again = more power
The Key is Patience and NOT rushing anything
  • 3 weeks later...
just another quick and possibly stupid question.
Am I worth while removing the left side crankshaft case when I do this and also if I do remove it do I need to drain the oil?
thanks
darren
There aren't any stupid questions, just verification to put your mind at rest.......nothing wrong in that
Dont you have a window (inspection cover) that removes so you can get to a bolt/nut connected to the crank that you turn to get TDC?
Cant say about Oil but it wont take more than a few minutes to drain it anyway
Do you have all the info on doing it?
I print out what I need and keep it in a plastic sleeved folder.....which is turning into a Book Now
Torque specs,
Head Bolt Torquing Sequence,
Cam Sprocket Markings,
Valve Timing adjustment,
Do you have to drop engine or Tilt it forward?
TIP:- Do the "work" in your head first, then do same in your head backwards before you even pick up a tool
Its instantly going to be a LOT easier than a 4 cylinder liquid cooled engine so thats good already
There is also a TW owners forum that will be a lot more knowledgeable about your engine at
www.tw200forum.com
You will def need head bolt torque setting because they are more likely to be TTY bolts and over doing them will make them stretch and need replacing
TTY= Torque to Yeild ....meaning they stretch when they hit their limit
I asked why because theres not usually anything useful on the left hand side/alternator end of the crankshaft. You can use the large nut and timing marks on the right hand end of the crank to do what you need to do.
The following is said in a nice way!
If you'd put that in your first post it might have been more helpful :wink: :lol:
well I tackled this job yesterday.
Had a bit of a nightmare as I couldn't figure out how to remove the tappets(not sure if that's what they are called), because I couldn't remove these I couldn't get the springs out so I had to replace the valve seals with the springs in place which was a right pain!!
So how did you get the Collets out!!! if you couldn't remove rocker arms! you would have had to compress springs, surely to remove collets and spring top to remove valve stem seal?
