2006> APRILIA RX 50 / SX 50 DESIGN FLAW FIXES
Guest SATAN
Here's a few fixes for some of the most annoying design flaws.
Cylinder head thermostat
Remove it, before it seizes shut.
http://www.laboutiquedelamoto.com/sites/default/files/styles/600px_marca_agua/public/cm151902.jpg?itok=sApNBlHa
Carburetor jetting issues
:arrow: This post
Oil filler cap
OEM transmission oil filler plug gets in the way of carburetor float chambers, which makes sliding out the carb for jetting changes more of a chore.
Voca VCR-SD9192/BK
Banana skin brake pedal replacement
Conti 1614TD0005 (knurled tip)
http://www.dam-sport.net/media/catalog/product/cache/1/image/800x530/0f00551ab62b14934f2cf581d3f166c3/1/6/1614TD0005.jpg
Coolant / oil leakage
Replace those metal washers.
Cylinder head and radiator thermoswitch plugs: M14 fiber washers.
Oil sump and clutch cover plugs: M10 fiber washers.
Ignition replacement
MVT Millennium EXT 111
Only ground the blue wire if you want to restrict top speed.
http://www.dam-sport.net/media/catalog/product/cache/1/image/800x530/0f00551ab62b14934f2cf581d3f166c3/E/X/EXT111.jpg
Long throttle twist fix
Domino 2203.03-02
Throttle cable: Derbi 863069
http://www.treatland.tv/v/vspfiles/photos/domino-throttle-2203.03-02-2.jpg
Analogue speedometer conversion
Speedometer: Derbi 864515
Speedometer cable: 00H01616021
17" SM wheel hub sensor: 00H01614051
21" enduro wheel hub sensor: 00H01613051
Bikes manufactured from 2013 with mag wheels require a 2006 - 2012 spoked front wheel.
Fuel gauge substitute
Put a 2mm blanking cap on the auto vacuum carb nipple.
Derbi Cross City 125 manual fuel tap: 00H00404181
This features a reserve fuel straw..
http://i751.photobucket.com/albums/xx157/tomsmithwork/DSCN2311.jpg?hotlinkfix=1507375386698
Secure the rear fender by drilling straight through its mounting lug holes with a 5mm bit. Use 5x50mm screws, 5mm star washers, and nyloc nuts. Acerbis's enduro rear fender bag is a perfect fit for Hünersdorff's Fuel Friend 1L container.
5mm plastic straight piece between fuel tap - carburetor line. Refill container from the bike's tank using the manual tap.
SX 50 chain guard rubbing off tyre wall
Use spacers, or grind swing arm mounting lugs off. Single seat bikes don't require chain guards for public road use.
2006-2009 headlight straps
When they split, replace them with Polisport Halo straps.
Preventing a damaged battery
Without a lid, it bounces around. Use a few pieces of high density foam underneath, and around it.
RX 50 soft fork spring fix
Marzocchi forks: use SX 50 springs and preload spacers
Kayaba forks: use SX 50 springs
Alternatively one could just get a proper motorcycle. Try to avoid anything with multiple design flaws . This is my proper motorcycle.http://i.imgur.com/25POB07.jpg
