Foxy Stoat seeks Pig Posted October 28, 2017 Share Posted October 28, 2017 When I loosened off the sump nut these bits fell out with the washer in the drip pan.It looks like thread from the sump. I have put new oil in and the washer and nut has tightened ok. I have had the bike running so it's hot and there is no leakage. Not been out for a run on it yet though.Not sure why/how this has happened. Quote Link to comment Share on other sites More sharing options...
prezz1 Posted October 28, 2017 Share Posted October 28, 2017 Hi, Its just a spring washer, it keeps the nut on very tight, you will find these around your bike, you don't need it on, if you find you are having to tighten the nut up more than, normal, then just put on another spring washer, dave Quote Link to comment Share on other sites More sharing options...
Westbeef Posted October 28, 2017 Share Posted October 28, 2017 You’ve not got my old bike have you? Quote Link to comment Share on other sites More sharing options...
Westbeef Posted October 28, 2017 Share Posted October 28, 2017 Hi, Its just a spring washer, it keeps the nut on very tight, you will find these around your bike, you don't need it on, if you find you are having to tighten the nut up more than, normal, then just put on another spring washer, dave Looks too thin too be a spring washer imo. Quote Link to comment Share on other sites More sharing options...
Jevi Posted October 28, 2017 Share Posted October 28, 2017 It looks like a stripped thread Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted October 28, 2017 Author Share Posted October 28, 2017 I think it's stripped although nut still tightened. so the last time it was tightened it must have stripped?? Quote Link to comment Share on other sites More sharing options...
TimR Posted October 28, 2017 Share Posted October 28, 2017 Possible helicoil insert .. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted October 28, 2017 Author Share Posted October 28, 2017 I'm going to have to Google that Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 28, 2017 Share Posted October 28, 2017 Its not a spring washer , sump plugs don't have spring washers. Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 28, 2017 Share Posted October 28, 2017 I think it's stripped although nut still tightened. so the last time it was tightened it must have stripped?? Hold on a minute, what's this thing made of ? It's white right ? So is it metal or plastic? Quote Link to comment Share on other sites More sharing options...
TimR Posted October 28, 2017 Share Posted October 28, 2017 I'm going to have to Google that Instead of retapping a thread you make it slightly larger and thread this in as a new original sized threadIf not fully/ correctly inserted they can break off the end but the main section remains hence it tightens Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 28, 2017 Share Posted October 28, 2017 Hi, Its just a spring washer, it keeps the nut on very tight, you will find these around your bike, you don't need it on, if you find you are having to tighten the nut up more than, normal, then just put on another spring washer, dave You don't have spring washers on sump plugs , how would the sump washer form an oil tight seal ? Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted October 28, 2017 Author Share Posted October 28, 2017 You’ve not got my old bike have you? You have had the same issue?? Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted October 28, 2017 Author Share Posted October 28, 2017 I think it's stripped although nut still tightened. so the last time it was tightened it must have stripped?? Hold on a minute, what's this thing made of ? It's white right ? So is it metal or plastic? It's metal pieces Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted October 28, 2017 Author Share Posted October 28, 2017 I'm going to have to Google that Instead of retapping a thread you make it slightly larger and thread this in as a new original sized threadIf not fully/ correctly inserted they can break off the end but the main section remains hence it tightens The nut is on tight now with no leakage but this looks like a fix going forward. Is it difficult to do? Quote Link to comment Share on other sites More sharing options...
Tango Posted October 28, 2017 Share Posted October 28, 2017 Yeah.....looks like bits of thread from the sump plug hole.......could have been over tightened in the past. Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 28, 2017 Share Posted October 28, 2017 I think it's stripped although nut still tightened. so the last time it was tightened it must have stripped?? Hold on a minute, what's this thing made of ? It's white right ? So is it metal or plastic? It's metal piecesRight, ill go with part of a Helicoil as well then. How about an extreme close up ? Quote Link to comment Share on other sites More sharing options...
Westbeef Posted October 28, 2017 Share Posted October 28, 2017 You’ve not got my old bike have you? You have had the same issue?? I cracked my sump and stripped the thread a little. Check for cracks and put the plug back in with some RTV silicone and you should be ok. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 28, 2017 Share Posted October 28, 2017 Keep an eye on it - if it don't leak, don't mess with it. My money's on it being a bit of helicoil insert as has previously been suggested. Quote Link to comment Share on other sites More sharing options...
Stu Posted October 28, 2017 Share Posted October 28, 2017 If it's tight and not leaking then leave it till the next oil change Definitely looks like part of a helicoil Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted October 28, 2017 Author Share Posted October 28, 2017 Hold on a minute, what's this thing made of ? It's white right ? So is it metal or plastic? It's metal piecesRight, ill go with part of a Helicoil as well then. How about an extreme close up ? Best I can do with my lousy camera phone and poor photography skills Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted October 28, 2017 Author Share Posted October 28, 2017 You’ve not got my old bike have you? You have had the same issue?? I cracked my sump and stripped the thread a little. Check for cracks and put the plug back in with some RTV silicone and you should be ok. No cracks in sump as far as I can see, plug and washer is already back in and 3 litres of new oil. I didn't think to use any silicone though. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted October 28, 2017 Author Share Posted October 28, 2017 Thanks for all the input so far, very helpful as always I tempted to leave it and see how it goes before I start buying helicoils, tap wrenchs etc. Have been looking on youtube though, seem like a handy bit of kit to have. Quote Link to comment Share on other sites More sharing options...
megawatt Posted October 28, 2017 Share Posted October 28, 2017 Doesn't look shiny enough for a helicoil. The cross section is diamond shaped. Looks like alloy thread or thread insert. Either way, you will probably have to repair the sump thread eventually. Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 28, 2017 Share Posted October 28, 2017 (edited) It's metal piecesRight, ill go with part of a Helicoil as well then. How about an extreme close up ? Best I can do with my lousy camera phone and poor photography skills Ok thanks for that , the bad news first, these now look like ripped out pieces of thread . They have a smooth triangular shape on the inside but are rough and flat on the outside suggesting that they have been broken away from the sump. The good news is that it hasn't already been Helicoiled so that is a repair that a good engineer can easily carry out. I don't know but there is a very good chance that the whole sump casting can be removed with the engine in the frame. If you do remove it this will present a rare opportunity to inspect the oil strainer gause and clean it if necessary,something that very rarely gets done in the life of a bike . An alternative might be to get a sump off eBay. Edited October 28, 2017 by fastbob Quote Link to comment Share on other sites More sharing options...
