Jevi Posted October 28, 2017 Share Posted October 28, 2017 My son has a Lexmoto Arizona, its his first bike since taking his CBT. We've had a few problems/gremlin's and I've had to replace a couple of things ( bulbs, kick start pedal and switchgear)Anyway, after first attempt at fixing the indicator's he took a test ride, he was out may be an hour and came back complaining that the bike had got up to about 45 and wouldn't go any faster ( oh and the indicator's had stopped working after about 30 mins).I've sorted the indicator's ( loose connection on relay) and after reading several item's on the pitstop forum I've checked the battery connections and the air filter. The bike starts from cold on the button with the choke fully open. I've let it sit idling for about 5 mins and gradually closed the choke. I've found that if I fully close the choke the bike stutters and dies.Is it possible that I haven't let it warm up enough? Would this have anything to do with the lack of power when riding? As I said I couldn't see anything wrong with the air filter and with the bike running if I put my hand over the mouth of the filter box the engine dies so I don't think we have any leaking hose's.Can anyone give me a clue where to look next? Quote Link to comment Share on other sites More sharing options...
Tango Posted October 28, 2017 Share Posted October 28, 2017 What's the bike's history?Have you tried fresh fuel in it if the stuff in the tank has been in there a while?.... Quote Link to comment Share on other sites More sharing options...
RantMachine Posted October 28, 2017 Share Posted October 28, 2017 Level ground? Because my Lexmoto couldn't break 50 if you went uphill or faced into the wind... Quote Link to comment Share on other sites More sharing options...
rider555 Posted October 28, 2017 Share Posted October 28, 2017 My son has a Lexmoto Arizona, its his first bike since taking his CBT. We've had a few problems/gremlin's and I've had to replace a couple of things ( bulbs, kick start pedal and switchgear)Anyway, after first attempt at fixing the indicator's he took a test ride, he was out may be an hour and came back complaining that the bike had got up to about 45 and wouldn't go any faster ( oh and the indicator's had stopped working after about 30 mins).I've sorted the indicator's ( loose connection on relay) and after reading several item's on the pitstop forum I've checked the battery connections and the air filter. The bike starts from cold on the button with the choke fully open. I've let it sit idling for about 5 mins and gradually closed the choke. I've found that if I fully close the choke the bike stutters and dies.Is it possible that I haven't let it warm up enough? Would this have anything to do with the lack of power when riding? As I said I couldn't see anything wrong with the air filter and with the bike running if I put my hand over the mouth of the filter box the engine dies so I don't think we have any leaking hose's.Can anyone give me a clue where to look next? Hi JeviFirst of all I wouldn't go by what the speedo is saying if that is what he is indicating to reference speed, my lexmoto speedo showing 75 when I'm doing 60, not bad if it was 75 but is not, ask him if it feels like the bike is accelerating but maybe just not showing? For choke I start mine up and I can manage only about 30-60 sec on choke then I have to fully open other wise bike will die, just adjust your idle screw a bit on carb and see if this will improve, could be just jets and carb need good cleaning, not a hard job, check your throttle cable going to carb, does your model have EGR valve? Link to near the same carb, will show you some basics and what is responsible for whathttp://www.ccwthariders.com/uploads/9/7/7/9/9779070/pz_carb_tuning_manual.pdf Quote Link to comment Share on other sites More sharing options...
Jevi Posted October 28, 2017 Author Share Posted October 28, 2017 Hello Tango - I might have just made it worse cos I've added another gallon to the tank today. I probably should have drained it first because I don't know how long the bike was standing before we got it.Rantmachime - he was on he level but might have had a head wind.Rider555 - I'm a bit wary of touching the carb but I'll give it a go with some carb cleaner and see what happens Quote Link to comment Share on other sites More sharing options...
Tango Posted October 28, 2017 Share Posted October 28, 2017 Has he tried it after you topped the tank up? Quote Link to comment Share on other sites More sharing options...
Jevi Posted October 28, 2017 Author Share Posted October 28, 2017 No but he's back home tomorrow so we'll see Quote Link to comment Share on other sites More sharing options...
Jevi Posted October 28, 2017 Author Share Posted October 28, 2017 No but he's back home tomorrow so we'll see if it's made a difference Quote Link to comment Share on other sites More sharing options...
rider555 Posted October 28, 2017 Share Posted October 28, 2017 Hello Tango - I might have just made it worse cos I've added another gallon to the tank today. I probably should have drained it first because I don't know how long the bike was standing before we got it.Rantmachime - he was on he level but might have had a head wind.Rider555 - I'm a bit wary of touching the carb but I'll give it a go with some carb cleaner and see what happens Try the bike with fuel added now, if is bit better then next drain, clean carb, refuel and go for ride. Quote Link to comment Share on other sites More sharing options...
Jevi Posted October 28, 2017 Author Share Posted October 28, 2017 Can do Quote Link to comment Share on other sites More sharing options...
LifeofPhil Posted October 28, 2017 Share Posted October 28, 2017 My son has a Lexmoto Arizona, its his first bike since taking his CBT. We've had a few problems/gremlin's and I've had to replace a couple of things ( bulbs, kick start pedal and switchgear)Anyway, after first attempt at fixing the indicator's he took a test ride, he was out may be an hour and came back complaining that the bike had got up to about 45 and wouldn't go any faster ( oh and the indicator's had stopped working after about 30 mins).I've sorted the indicator's ( loose connection on relay) and after reading several item's on the pitstop forum I've checked the battery connections and the air filter. The bike starts from cold on the button with the choke fully open. I've let it sit idling for about 5 mins and gradually closed the choke. I've found that if I fully close the choke the bike stutters and dies.Is it possible that I haven't let it warm up enough? Would this have anything to do with the lack of power when riding? As I said I couldn't see anything wrong with the air filter and with the bike running if I put my hand over the mouth of the filter box the engine dies so I don't think we have any leaking hose's.Can anyone give me a clue where to look next? Hi JeviFirst of all I wouldn't go by what the speedo is saying if that is what he is indicating to reference speed, my lexmoto speedo showing 75 when I'm doing 60, not bad if it was 75 but is not, ask him if it feels like the bike is accelerating but maybe just not showing? For choke I start mine up and I can manage only about 30-60 sec on choke then I have to fully open other wise bike will die, just adjust your idle screw a bit on carb and see if this will improve, could be just jets and carb need good cleaning, not a hard job, check your throttle cable going to carb, does your model have EGR valve? Link to near the same carb, will show you some basics and what is responsible for whathttp://www.ccwthariders.com/uploads/9/7/7/9/9779070/pz_carb_tuning_manual.pdf ...ish. how could you measure speed with out access to a speed gun? I'm curious to know if I'm doing the speeds my bike says I'm doing Quote Link to comment Share on other sites More sharing options...
fastbob Posted October 28, 2017 Share Posted October 28, 2017 How about a Lexmoto sub forum ? Quote Link to comment Share on other sites More sharing options...
rider555 Posted October 28, 2017 Share Posted October 28, 2017 My son has a Lexmoto Arizona, its his first bike since taking his CBT. We've had a few problems/gremlin's and I've had to replace a couple of things ( bulbs, kick start pedal and switchgear)Anyway, after first attempt at fixing the indicator's he took a test ride, he was out may be an hour and came back complaining that the bike had got up to about 45 and wouldn't go any faster ( oh and the indicator's had stopped working after about 30 mins).I've sorted the indicator's ( loose connection on relay) and after reading several item's on the pitstop forum I've checked the battery connections and the air filter. The bike starts from cold on the button with the choke fully open. I've let it sit idling for about 5 mins and gradually closed the choke. I've found that if I fully close the choke the bike stutters and dies.Is it possible that I haven't let it warm up enough? Would this have anything to do with the lack of power when riding? As I said I couldn't see anything wrong with the air filter and with the bike running if I put my hand over the mouth of the filter box the engine dies so I don't think we have any leaking hose's.Can anyone give me a clue where to look next? Hi JeviFirst of all I wouldn't go by what the speedo is saying if that is what he is indicating to reference speed, my lexmoto speedo showing 75 when I'm doing 60, not bad if it was 75 but is not, ask him if it feels like the bike is accelerating but maybe just not showing? For choke I start mine up and I can manage only about 30-60 sec on choke then I have to fully open other wise bike will die, just adjust your idle screw a bit on carb and see if this will improve, could be just jets and carb need good cleaning, not a hard job, check your throttle cable going to carb, does your model have EGR valve? Link to near the same carb, will show you some basics and what is responsible for whathttp://www.ccwthariders.com/uploads/9/7/7/9/9779070/pz_carb_tuning_manual.pdf ...ish. how could you measure speed with out access to a speed gun? I'm curious to know if I'm doing the speeds my bike says I'm doing Easy, GPS app and I had also friend on another bike to compare result Quote Link to comment Share on other sites More sharing options...
rider555 Posted October 28, 2017 Share Posted October 28, 2017 How about a Lexmoto sub forum ? Sounds good but there are not very liked bikes on Forums Quote Link to comment Share on other sites More sharing options...
Jevi Posted November 4, 2017 Author Share Posted November 4, 2017 Think we're sorted, pulled the plug and found it to be very black and wet. Cleaned it up and checked the gapping before refitting, my son got up to 60 (downhill,wind assisted). I've got a colortune plug so will have a go at setting up the carb and will be fitting an inline fuel filter to stop any crap in the tank buggering up the flow. Quote Link to comment Share on other sites More sharing options...
Tango Posted November 5, 2017 Share Posted November 5, 2017 Think we're sorted, pulled the plug and found it to be very black and wet. Cleaned it up and checked the gapping before refitting, my son got up to 60 (downhill,wind assisted). I've got a colortune plug so will have a go at setting up the carb and will be fitting an inline fuel filter to stop any crap in the tank buggering up the flow. Good news mate......check that the air filter isn't clogged, which would make it run rich...... Quote Link to comment Share on other sites More sharing options...
rider555 Posted November 5, 2017 Share Posted November 5, 2017 Think we're sorted, pulled the plug and found it to be very black and wet. Cleaned it up and checked the gapping before refitting, my son got up to 60 (downhill,wind assisted). I've got a colortune plug so will have a go at setting up the carb and will be fitting an inline fuel filter to stop any crap in the tank buggering up the flow. glad you got it sorted, I had to google it what you mean by colortune plug , after quick read very handy thing to have , might invest in one Quote Link to comment Share on other sites More sharing options...
