SlowBusa Posted January 21, 2018 Share Posted January 21, 2018 The Below is for APE CHN10125.10 head nuts and CS1300STN Cylinder head studs that I have on my bikeDoes anyone know where I can buy Nuts by Thread AND Hex size?OR a stud installer of the below dimensionsThe reason is I need a nut(or 2 nuts) with the following dimensions.......M10 1.25mm pitch and 14mm Hex size (spanner size 14)The solution is a Stud Installer, but it has to have locking allen key on Topbut every stud installer Ive found is 17-19 spanner size ...and room is a factor for cylinder head studs/nuts on my bikeAPE do One for my setup but cant find one in the UK My solution was to Slot the Studs and install with a screwdriver socket attachment (it works but not desirable), but would like to find a nut/installer for the right job Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted January 21, 2018 Share Posted January 21, 2018 Have you tried 2 nuts on the stud, tightened agaist each other.Install the stud. Use 2 spanners to remove the nuts. Quote Link to comment Share on other sites More sharing options...
SlowBusa Posted January 21, 2018 Author Share Posted January 21, 2018 The problem is the nuts are the same dimensions as the pic and it dosnt leave any room for 2 and the dimensions are tight and sunken into the headWhen the Nut is on and tightened down there is probably only 1 mm thread proud of the nut surface Quote Link to comment Share on other sites More sharing options...
Bianco2564 Posted January 21, 2018 Share Posted January 21, 2018 Can't you make your own out of 14mm hex bar? Quote Link to comment Share on other sites More sharing options...
SlowBusa Posted January 21, 2018 Author Share Posted January 21, 2018 Can't you make your own out of 14mm hex bar? beyond my capabilities im afraidalthough its something i should look into Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted January 21, 2018 Share Posted January 21, 2018 Hold up, let me get this straight as I'm quite tired and slightly pissed.You want a couple of nuts 14mm across flats with an M10 thread or something that looks a bit like the pic with M10 & 14mm AF with a grub screw in the top.I might be able to knock something up if you're stuck. Quote Link to comment Share on other sites More sharing options...
SlowBusa Posted January 22, 2018 Author Share Posted January 22, 2018 Hold up, let me get this straight as I'm quite tired and slightly pissed.You want a couple of nuts 14mm across flats with an M10 thread or something that looks a bit like the pic with M10 & 14mm AF with a grub screw in the top.I might be able to knock something up if you're stuck.That would be incredible if you couldPM on way Quote Link to comment Share on other sites More sharing options...
SlowBusa Posted January 27, 2018 Author Share Posted January 27, 2018 A HUGE THANKS to[mention]Mr Fro[/mention] Quote Link to comment Share on other sites More sharing options...
