Mr_Adrenaline125 Posted January 26, 2018 Share Posted January 26, 2018 hi everyone, i have a problem with me bike, lexmoto adrenaline 125 2016, twice now it has cut power out on me and i cant seem to fix the problem! i bought a new ignition barrel for it, it worked fine now it doesnt seem to work at all!! any help?? Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 26, 2018 Share Posted January 26, 2018 Looks like another one for for the Lexmoto electrical fault section. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 26, 2018 Share Posted January 26, 2018 And the clue is..? Quote Link to comment Share on other sites More sharing options...
Tango Posted January 26, 2018 Share Posted January 26, 2018 You'll need a multimeter and wiring diagram......then just follow the live feed until it disappears.......but it sounds like the ignition barrel again......or possibly the starter relay, which I think is placed where rain water just runs into it and kills it..... Quote Link to comment Share on other sites More sharing options...
0281-E Stuart Posted January 30, 2018 Share Posted January 30, 2018 hi everyone, i have a problem with me bike, lexmoto adrenaline 125 2016, twice now it has cut power out on me and i cant seem to fix the problem! i bought a new ignition barrel for it, it worked fine now it doesnt seem to work at all!! any help?? Hello My Friend,I've had this issue before, when the bike was brand new.My problem was a loose main fuse on the positive terminal for the battery. I simply removed the fairing covering the battery, removed the fuse and pushed the two clips together at either end of the holder so that the fuse was much tighter.Never had a problem since.I hope this helps and please let us know how it goes!Best Regards,Stuart. Quote Link to comment Share on other sites More sharing options...
Liamtms1703 Posted March 9, 2022 Share Posted March 9, 2022 i have a pulse adrenaline 125cc its not getting any power unless its connected up to a boost started but even then its still like its not enough power to start the bike.. there is no idicators or back light on this bike.. would that be the problem or would it be anything else ive tried charging the battery and im still not getting anything when i put the battery back in it.. ive also tried multiple batterys but still nothing.. if someone can get back to me via my email i will be very grateful! Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted March 9, 2022 Share Posted March 9, 2022 Sounds as if the starter motor is the problem. I had problems with my GSX600, it would start but only just, turning over slow. Jump start with jump leads no better. I took starter off and looked inside. Brushes were worn down, only making contact with some of the rotor. New starter and it has been perfect since. Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted March 9, 2022 Share Posted March 9, 2022 5 hours ago, iangaryprice said: Sounds as if the starter motor is the problem. I had problems with my GSX600, it would start but only just, turning over slow. Jump start with jump leads no better. I took starter off and looked inside. Brushes were worn down, only making contact with some of the rotor. New starter and it has been perfect since. You can replace the brushes quite easily - Cheaper than a new starter Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted March 9, 2022 Share Posted March 9, 2022 1 hour ago, Grumpy Old Git said: You can replace the brushes quite easily - Cheaper than a new starter If you can get them its the cheapest way, for my bike I couldn't get a brush pack, luckily a new starter was only £60. Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted March 11, 2022 Share Posted March 11, 2022 You can buy a set that is too large and then grind them to size - Did this for the Rocket (getting the starter motor out in the first place was a complete nightmare!) Quote Link to comment Share on other sites More sharing options...
