Guest Posted January 31, 2018 Share Posted January 31, 2018 Need help my hyosung gt125r 2008 is giving me trouble, it’s taken two falls and after that the bike has start spluttering all the time when I take of when I’m driving when I fill the tank it seems to get better, but obviously isn’t great won’t idle just cuts out, I’ve cleaned the air box, cleaned the carbs pipes are clear just don’t know what it is. Quote Link to comment Share on other sites More sharing options...
rennie Posted February 1, 2018 Share Posted February 1, 2018 Hello and Welcome Sounds like you've got air trapped somewhere in the fuelsystem to me!Is the breather pipe clear? Quote Link to comment Share on other sites More sharing options...
0281-E Stuart Posted February 1, 2018 Share Posted February 1, 2018 Welcome aboard!I agree with rennie, sounds like air in the fuel system. Keep us updated.Best of luck,Stuart. Quote Link to comment Share on other sites More sharing options...
Snod Blatter Posted February 2, 2018 Share Posted February 2, 2018 I would suggest the strainer on the fuel tap might be clogged with rust, but as the tap appears to be vacuum controlled it won't be easy to test. Is the tank rusty on the inside? Quote Link to comment Share on other sites More sharing options...
Tango Posted February 3, 2018 Share Posted February 3, 2018 Chances are that the falls have stirred up the crap in the bottom of the tank and some of it has either clogged the strainer, or has got into the carb........strip and flush of the tank and carb I think is in order..... Quote Link to comment Share on other sites More sharing options...
