Foxy Stoat seeks Pig Posted March 27, 2018 Share Posted March 27, 2018 I filled up last Thursday and my fuel gauge has only gone down one bar. Now it would be nice if this was a true reflection of my fuel consumption but I know its simply not true. Its a digital gauge and it was fine until the last fill up. Any ideas what could have gone wrong and how I would go about fixing it?Thanks all. Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted March 27, 2018 Share Posted March 27, 2018 Never really trustred them best to zero the trip meter. Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted March 27, 2018 Share Posted March 27, 2018 I have a digital gauge and mine shows full bars until it gets to half full. It then becomes more accurate and goes down one bar at a time until the bars disappear and I got onto reserve. It then counts down from 40 miles. Have you had your bike long? Could this be the same as yours? Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted March 27, 2018 Author Share Posted March 27, 2018 Quote Link to comment Share on other sites More sharing options...
Gerontious Posted March 27, 2018 Share Posted March 27, 2018 I have a digital gauge and mine shows full bars until it gets to half full. It then becomes more accurate and goes down one bar at a time until the bars disappear and I got onto reserve. It then counts down from 40 miles. my 800 is exactly the same. its a rough guide until the last 100 or so miles and then becomes more accurate. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted March 27, 2018 Author Share Posted March 27, 2018 I have a digital gauge and mine shows full bars until it gets to half full. It then becomes more accurate and goes down one bar at a time until the bars disappear and I got onto reserve. It then counts down from 40 miles. Have you had your bike long? Could this be the same as yours? Had it since Sept 2016. Never had an issue before, level always dropped as expected. Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted March 27, 2018 Share Posted March 27, 2018 I would take it in then. See what the mechanic suggests Quote Link to comment Share on other sites More sharing options...
Stu Posted March 27, 2018 Share Posted March 27, 2018 could be a sticking level sensor if its the float type Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted March 27, 2018 Author Share Posted March 27, 2018 could be a sticking level sensor if its the float type Wouldn't have a clue, will need to do some research.I usually keep it topped up with fuel so not really a massive problem, more annoying than anything. Quote Link to comment Share on other sites More sharing options...
Stu Posted March 27, 2018 Share Posted March 27, 2018 could be a sticking level sensor if its the float type Wouldn't have a clue, will need to do some research.I usually keep it topped up with fuel so not really a massive problem, more annoying than anything. https://www.ebay.co.uk/itm/2003-Yamaha-FZ6-600-FAZER-2004-2010-Fuel-Pump-/292434472961?clk_rvr_id=1480435798371&utm_medium=cpc&utm_source=twenga&utm_campaign=twenga&utm_param=eyJlcyI6MCwicyI6OTcyMDIzNywiY2kiOiIwM2I4Nzk1MzljYWI1NzlkOWQ1ZDc0YWQzMDdjZDc3YyIsImkiOiIyOTI0MzQ0NzI5NjEiLCJ0cyI6MTUyMjE4MTA5OSwidiI6Mywic28iOjE1MDAsImMiOjE3Nzc4MH0%3D&rmvSB=true you can see the black float at the end of the fuel pump Quote Link to comment Share on other sites More sharing options...
megawatt Posted March 27, 2018 Share Posted March 27, 2018 Take tank off when nearly empty, give it a gentle shake 3 or 4 times, then refit. Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted April 5, 2018 Author Share Posted April 5, 2018 Erm yeah so probably so to fess up The reason why the 'faulty' gauge was not going down is because I had filled up only two days before hand. Doh!! In my defence, if there is any, I have been very tired, doing overtime, chronic tooth ache, and taking far to many painkillers. I still can't remember filling up but the receipt in my wallet states otherwise..... Quote Link to comment Share on other sites More sharing options...
TimR Posted April 5, 2018 Share Posted April 5, 2018 Erm yeah so probably so to fess up The reason why the 'faulty' gauge was not going down is because I had filled up only two days before hand. Doh!! In my defence, if there is any, I have been very tired, doing overtime, chronic tooth ache, and taking far to many painkillers. I still can't remember filling up but the receipt in my wallet states otherwise..... Paging the Jim Henson Creations team .... one of your subjects is loose . Quote Link to comment Share on other sites More sharing options...
Foxy Stoat seeks Pig Posted April 5, 2018 Author Share Posted April 5, 2018 Erm yeah so probably so to fess up The reason why the 'faulty' gauge was not going down is because I had filled up only two days before hand. Doh!! In my defence, if there is any, I have been very tired, doing overtime, chronic tooth ache, and taking far to many painkillers. I still can't remember filling up but the receipt in my wallet states otherwise..... Paging the Jim Henson Creations team .... one of your subjects is loose . it was a bad week Quote Link to comment Share on other sites More sharing options...
Stu Posted April 5, 2018 Share Posted April 5, 2018 Erm yeah so probably so to fess up The reason why the 'faulty' gauge was not going down is because I had filled up only two days before hand. Doh!! In my defence, if there is any, I have been very tired, doing overtime, chronic tooth ache, and taking far to many painkillers. I still can't remember filling up but the receipt in my wallet states otherwise..... simple trick reset the miles every time you fill up and check what mileage you have done against the fuel gauge Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted April 5, 2018 Share Posted April 5, 2018 Quote Link to comment Share on other sites More sharing options...
Hoggs Posted April 5, 2018 Share Posted April 5, 2018 Erm yeah so probably so to fess up The reason why the 'faulty' gauge was not going down is because I had filled up only two days before hand. Doh!! In my defence, if there is any, I have been very tired, doing overtime, chronic tooth ache, and taking far to many painkillers. I still can't remember filling up but the receipt in my wallet states otherwise..... well thank you for the laugh! probably not even breaking the top 10 d'oh forum moments though (thibk beefy has that locked out) Quote Link to comment Share on other sites More sharing options...
