Philmorgs Posted April 1, 2018 Share Posted April 1, 2018 Recently did an oil and filter change on my sv, just wondering the correct way about checking the levels, do you check oil when cold or do you have to warm it up for a while then check? Noob question but not 100percent! Cheers guys Quote Link to comment Share on other sites More sharing options...
Gerontious Posted April 1, 2018 Share Posted April 1, 2018 (edited) The owners manual says.1. Place the motorcycle on level ground on the side stand.2. Start the engine and allow it to idle for a few minutes.3. Stop the engine and wait for 3 minutes.4. Hold the motorcycle vertically and check the level through the oil inspection window on the right hand side of the engine. the oil level should be between the L low and F full lines.(Edited for spelling) Edited April 1, 2018 by Gerontious Quote Link to comment Share on other sites More sharing options...
TimR Posted April 1, 2018 Share Posted April 1, 2018 Best procedure is as stated in owners manualThere are a variant of ways so as above if you can find the above is best( these are for various manufacturers some may not be relevantPlace bike on centre stand and leave for 5 mins ( cold engine) check level Place on centre stand , run engine for five ( or variant ) minutes .stop engine) Leave for 5 minutes . Check level.Run engine , Stop engine , allow 5 mins and level bike and check level ( kawasaki gtr1400 Method with a sight glass on the right hand side )Check from cold on the level Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 1, 2018 Share Posted April 1, 2018 Next time use a measuring jug . ( and then put in a splosh for good luck ) Quote Link to comment Share on other sites More sharing options...
