kezzington Posted April 10, 2018 Share Posted April 10, 2018 Bike AJS DD 2006SO im having a major issue with my commuter bike.came out after work this morning to find my cover off bike soaked and unable to start ... or should i say no electrics at all!!!! can anyone advise on what to try here ? Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted April 10, 2018 Share Posted April 10, 2018 Has some scumbag stolen the battery, or other bits for that matter? Quote Link to comment Share on other sites More sharing options...
kezzington Posted April 10, 2018 Author Share Posted April 10, 2018 lucky not ive checked all the electrics i can see / battery nothing is wrong i cant check the battery charge sadly but it run (bum) start the bike left her running for half hour and zero charge still Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted April 10, 2018 Share Posted April 10, 2018 If it ran ok after bump start it sounds like battery is knackered, get a new one. But also check that the alternator is charging the battery. You need a test meter to show the battery voltage prior to starting and after starting. Quote Link to comment Share on other sites More sharing options...
kezzington Posted April 10, 2018 Author Share Posted April 10, 2018 it has to be the alternator then =[ the battery is only a few months old Quote Link to comment Share on other sites More sharing options...
kezzington Posted April 10, 2018 Author Share Posted April 10, 2018 i Feel like such an idiot .... my friend came over to take a look pulled out a hidden wire and said it was a blown fuse D= which it was i am such a tool thanks guys Quote Link to comment Share on other sites More sharing options...
fastbob Posted April 10, 2018 Share Posted April 10, 2018 i Feel like such an idiot .... my friend came over to take a look pulled out a hidden wire and said it was a blown fuse D= which it was i am such a tool thanks guys Glad you fixed it, so how do you BUM start a bike ? Sounds painful. Next job is to try to find out what caused the fuse to blow . Quote Link to comment Share on other sites More sharing options...
kezzington Posted April 11, 2018 Author Share Posted April 11, 2018 Knock it in gear pull the clutch move the bike pet go of the clutch grab the clut h again before it stalls and YES I realise I put bum not bump xD Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted April 11, 2018 Share Posted April 11, 2018 Did you find out what caused the fuse to blow? So if it happens again you need to investigate further. Quote Link to comment Share on other sites More sharing options...
